PLEASE ANSWER MY STUPID QUESTIONS >
Old 02-26-2013, 04:33 PM
  #16
losiracing2.0's Avatar
Calibration is really very simple, you just press and hold the MODE button for 3 seconds to enter radio calibrate, let the speed control “find” your neutral, then let it “find” your full throttle and full brake
losiracing2.0 is offline
Old 02-26-2013, 04:36 PM
  #17
Originally Posted by losiracing2.0
Okay did you set your end points on your esc?
Then again I don't know what that means... I'm a newbie...
NickChitwood126 is offline
  #18
Trader Rating: 60 (100%+)
make sure the brown wire faces out and the Orange wire is faces inside. thr is throttle your lead for the ESC plugs into that slot. the servo lead st is for steering its under thr. plug them in with the brown wires on the pugs facing out.
Graphite07 is offline
  #19
Didn't see where you put this. I'm about to try it now. Thanks for sticking with me!!!
Old 02-26-2013, 05:19 PM
  #20
Team Tekin
Randy_Pike's Avatar
Nick being a "newbie" is no excuse for NOT reading the instructions. I STRONGLY suggest doing so. You're messing with some high end racing level electronics that if you do something wrong, can be damaged.
Randy_Pike is offline
Old 02-26-2013, 06:52 PM
  #21
Did you get it working?
