SC10 vs SCTE rims
Old 02-12-2013, 12:38 PM
Default SC10 vs SCTE rims
Does anyone know what the offset difference is between these rims. Can I use the sc10 rims on the scte or the other way around? Thanks for any help.
Rawwolf is offline
Old 02-12-2013, 03:12 PM
Trader Rating: 17 (100%+)
The SC10 rims will not work on the SCTE, they rub on the hub carriers when you turn the wheels. You can run the SCTE rims on the SC10, though.
Snafujg is offline
Old 02-12-2013, 03:35 PM
T. Herwig's Avatar
Trader Rating: 25 (100%+)
SCTE is 0 offset and SC10 uses a +3 style wheel. They will not work without modification.
T. Herwig is offline
Old 02-12-2013, 03:46 PM
brian94066's Avatar
Read somewhere that stock no offset SC10 wheels have 1.4mm more offset than the SCTE wheels, so +3 SC10 wheels have 4.4mm more offset
brian94066 is offline
Old 02-12-2013, 04:54 PM
proline renegade will with some trimming
http://www.youtube.com/watch?feature...&v=O6Kg7W0rzZI
azonic155 is offline
Old 02-13-2013, 06:42 AM
Trader Rating: 55 (97%+)
+1
shagnat is offline
Old 02-13-2013, 08:45 AM
LVBaja's Avatar
SC 10 wheels will work on the SCTE, but you'll need to dremel out a portion of the inner wheel (see below).
LVBaja is offline
