Storage charge rate?
#16
Hey Guys, I'm getting back in hobby after a long lay off so the girlfriends kid can race. So the lipo thing is new for me, is doing a discharge the same as using the storage mode on the charger? If not, is one way better than the other? Thanks.
#17
There is no good reason to discharge a lipo unless it's holding a lot of charge and you want to store it. As long as you're using if somewhat frequently and leave it about 1/2 charged, you're good.
#18
#19
Lower amp rates charging and discharging will give your batteries a longer lifespan. Discharge them as slow as you have the patience for.
#21
How does that contradict my last post.?...I said that I store them at full charge, cause the other bats I had got puffy...and I was storing them at half full....so now thatbi store these at full, they havnt puffed yet
#22
Storage Charge with a Hitec. Seems to work well. I have let some sit at 100% with no ill effects.
#23
#24
Generally more of a problem with higher performance lipos.
Curious, how low do you typically run/discharge them?
#25
Agree with Davidka that discharging is rarely needed. Perhaps occasionally as a capacity check as one measure of condition. But be careful, lipos don't like heavy discharges. Most chargers discharge slowly and thus need a higher cutoff voltage than when running in a RC. Reason is the higher load of the RC causes more voltage drop than a slow charger discharge. 3.6V/cell on a typical 5 to 10W discharge power charger is pretty low relative to lipo capacity. Perhaps a little lower than 3.6V if you have a higher discharge capable device, in the 10 amps or higher range.
#26
