What 1/8 buggy to buy!!?!!
#19
buy a used roller of whatever you can get parts easiest for. then pick up a tekno conversion kit, hobbywing 80amp/2250 combo. basic dsm will work fine - this cheapo plan led to podium finishes every time i raced, with MANY different brands of different rollers (between 3-4 years with 8e), no lie (and i never had fresh tires, lol)......absolutely a no brainer, and i think no one can argue - thrashed roller, tekno conversion kit (freshens it up AND makes an unreal handling platform), hobbywing 80amp/2250kv combo
#22
have you been able to find parts for this easily? And what other buggys have you owned to compare to?Looking at this buggy it appears to be of good quality however it is at the top of the price range i would like too spend(witch is why i ask what other buggys you have owned and are comparing it too)
Thanks again for the advice
Serpent 811be
MBX6 Eco
RC8.2
Ofna Hyper 9e
Hot Bodies Ve8 with HHH chassis
Xray
#24
#25
OK so to update my opinion on everything i am thinking ill look around for a decent used roller if i can find one otherwise bite the bullet on a big money roller such as the serpent .
As far as the electronics i am thinking ill use :
Hobbywing 150a esc $95
most likely a tekin 1900 kv motor $140
Spektrum Dxs3 w/ 2 rx's &telmetry $150
So far i still need a servo(probably have to pick a roller first i assume?) and the roller itself. The speed passion esc recommended above was described as a 1/10 esc and also only accepts 2s lipos. The hobbywing esc shows up to a 6s battery so can i run 2 3s batteries with it?(this would allow me to run a 3s in my touring car so i can interchange batteries for on/off road race days).
Still looking at chargers i'm leaning towards getting atleast two 4100 mah 40c 11.1v 3s batteries (if i can run dual battery) @ $40.00 each
#26
If you are interested in the DXR-8E, there's a very active thread on here. Tower/Duratrax/Hobbico has awesome customer service. I've hit it up twice, and both times, positive experience...
The vehicle is good, very good design, if you are planning to race, a few upgrades brings it up to par with the high end stuff out there...
#27
http://www.amainhobbies.com/product_...-Speed-Control
also, any particular reason why you want to run 3s batteries?
#28
not sure which speed passion esc you looked up.
and also i see that esc is different from the one i looked up but its still more expensive then the hobbywing so unless there is a significant difference ill probably go with the hobbywing(i am about to read into them to try and see if there is one)
#29
