Old 04-23-2005, 07:35 PM   #1
Default Evader Diff, Help Please!!! (brushless)
g day guys i have an evader with a novak brushless and this thing is great ( when its going) my question to all you greatly informed people s can i replace teh brass bushings in the slipper clutch witha bearing????? i am chewing out the bushing!! can this be made a bearing or is it intended to stay solid
any help would be great thanks!!!!
wingspan is offline   Reply With Quote
Old 04-24-2005, 12:58 AM   #2
c'mon tech gurus!!!!! ideas??
Old 04-25-2005, 05:34 AM   #3
hello anyone out there
Old 04-25-2005, 10:53 AM   #4
kufman's Avatar
I replaced the bushing in my T3's slipper with a bearing and it works fine for me. I haven't personally looked at the design of the duratrax slipper, but it is probably very similiar. You may have to be careful on how things push on a bearing. Normal bearings are not made to be used as thrust bearings. In the T3 it is just there to keep the spur gear centered. What part of the bushing are you tearing up? The outter surfaces or the inner part that rides on the to shaft?
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 04-25-2005, 10:20 PM   #5
the face of the bushing is wearing out badly by the next washer in front of it, the washer in front is fine it has no burrs etc..
Old 04-25-2005, 10:39 PM   #6
Trader Rating: 28 (100%+)
Well if something is tearing the face of the bushing out, it'll probably do the same to a bearing. Not to mention on a bearing the force should be on the inner race, not the outside edge of the bearing. I'd try and find out what is causing your problem. Slippers shouldn't slip that much. Normally they are revolving with the rest of the drivetrain. Are you running it to loose? Maybe the brushless setup is to much torque.
jbrow1 is offline   Reply With Quote
Old 04-26-2005, 04:49 AM   #7
yes i think the brushless has too much torque for this set up but im not gonna change it!!! it is too much fun im ust gonna have to find a way of bulletproofing it !!!!!!
Old 04-26-2005, 09:44 AM   #8
Tighten the slipper a bit more, maybe run some grease between teh bushing and washer, and maybe try some rear tires tha have a bit less tractions.
Old 04-27-2005, 07:03 AM   #9
less traction what are you talkin about i cant keep the thing straight now due to wheel spin
mmmmm i have some ideas ill see how they work out and post up with results of bullet proof diff
Old 04-27-2005, 09:51 AM   #10
I was meaning if your slipper is slipping that much maybe you should get tires that aren't as hooked up. But if you already got big wheelspin I'd say the motor system is just to powerful for your truck. Have fun!!
Corally RDX brushless...diff..??'s GSPOT Electric On-Road 2 12-08-2007 08:20 PM
brushless help on evader st pro ashunte Electric Off-Road 1 11-20-2007 05:56 PM
pics of my play toys!!!!! evader x3 1 brushless wingspan Electric Off-Road 1 04-30-2005 06:05 AM
Duracrap evader diff problem Cardboard Electric Off-Road 7 11-19-2004 06:54 AM
would it be ok to put a brushless motor in a evader st ferrariboy69 Electric On-Road 2 06-13-2004 03:57 PM
