Old 04-26-2005, 08:00 AM   #16
Phroziac's Avatar
Send a message via AIM to Phroziac Send a message via Yahoo to Phroziac
Yes, clean car = fast car. If its an electric, it doesn't take much cleaning if you dont get it wet. If you run slicks, clean, sticky slicks are much sticker then dirty ones.
Phroziac is offline   Reply With Quote
Old 04-29-2005, 10:41 PM   #17
netmaster's Avatar
For weekly cleanings I use a air compressor, denatured alcohol, and simple green.
Then once in a while I will remove the electronics and motor and spray it with simple green, then hose it off. I then use a heat gun and the air compressor to make sure all the water is gone. I then spray the moving parts with wd-40.
netmaster is offline   Reply With Quote
Old 04-30-2005, 12:27 PM   #18
Best advice period. Forget the biggest and best stuff. This one of the fundementals of racing. I clean mine once a week. Shock rebuilds once every 2 weeks. Diff rebuilds about once a month. Spray out bearings and polish hinge pins as much as possible. Simple green
runnin rc10 is offline   Reply With Quote
Old 04-30-2005, 02:56 PM   #19
performula's Avatar
I use denatured alcohol, but the cost ends up roughly being $3.00-$5.00 each spray down.
performula is offline   Reply With Quote
Old 05-04-2005, 07:03 PM   #20
rushdude's Avatar
Send a message via AIM to rushdude
Denatured alchohol is the best. $5 at home depot for a half gallon. It wont affect your servos becuase it is an evaporating cleaner. I use that along with my air compressor while the engine is out.
rushdude is offline   Reply With Quote
Old 05-04-2005, 07:05 PM   #21
rushdude's Avatar
If you are using a whole half gallon that is way too much, or you are being over charged.
i need a ride rc31cli Georgia Racing 5 03-18-2008 01:45 PM
what ride? Rollondis Electric On-Road 0 08-31-2007 11:11 PM
My new ride LosiSuperTruck Monster Trucks 0 07-04-2006 11:43 PM
Anyone want to try a new ride? volracer Alabama Racing 0 02-20-2006 02:33 PM
MY Ride! Clint ODell Nitro On-Road 7 01-19-2004 08:32 PM
