TLR TEN-SCTE 2.0 Kit Thread
#6946
Can someone tell me if there's any other option available for getting these shock O-rings? http://www.amain.com/product_info.ph...ld-Set-2-Ten-T
And are these the correct rod ends for the 2.0 or is the plastic different? http://www.amain.com/product_info.ph...d-Set-15-Ten-T
Plastics are the same.
#6947
I've bent my stock chassis and cannot decide should I get the stock or some aftermarker chassis (BCE..?).
How are those aftermarket parts compared to the stock one? I'm running mostly indoors tight med bite track.
#6949
Hey guys...i anyone here running a 2 pole motor? I just killed my 4 pole revtech and looking for something else...I was going to go with a 4 pole Hobby Wing, but saw they offered a 2 pole motor. I hear they are smoother and easier to get power down with, but how much and i going to lose going from 4 to 2 poles?
I wish I moved to a 2 pole sooner. Hopefully it will show this weekend at the Hot Rod Hobbies Shootout.
#6951
Ok, sorry to hear that. Maybe I'll just try to bend my chassis back and see how it goes. Thanks guys!
#6952
Thanks. I had an o-ring swell a few months ago, probably from the electrical cleaner I use to clean shocks when rebuilding them. Just wanted to pick up some more in case of an emergency.
#6953
Is Kingheadz motor mount and C-diff support worth the money ? or a needed upgrade ?
thanks, Cory
thanks, Cory
#6955
Yeah I would not recommend electrical cleaner to clear out the shocks. I typically just wipe dirt off the bottom of the shock caps and then just drain the old only and pour in new oil. If you are going to spray out your shocks take the o-ring stack out then spray out your shock bodies and reassemble the shocks.
#6956
Bought a set of the Green beadlock rings for my other set of rims which came in the kit, i was disappointed to find they are painted, so the first time you touch a pipe or a wall they will get scratched and look crap, I should have bought white ones and dyed them myself
#6957
this maybe a dumb question but it's never stopped me before ...lol
is the center diff housing and the front and rear housings the same just different out drives ?
I was looking on amain and cant find a dang center differential lol
thanks in advance, Cory
#6959
#6960
u got those steering drag links installed upside down bearing goes up
