TLR TEN-SCTE 2.0 Kit Thread > TLR TEN-SCTE 2.0 Kit Thread
Like Tree6Likes
Old 02-19-2014, 10:16 PM
  #6226
Trader Rating: 15 (100%+)
Originally Posted by banana rt View Post
id love how my 2.0 ran. but it always frustating to see my wheel coming off even i nut em tightly. and i realize my inner hex chipped out, how to fix this problems, coz it happens over and over.
Serrated wheel nuts did the trick for me. http://www.amainhobbies.com/product_...-Nut-Set-Black
Tommygun1 is offline
Old 02-19-2014, 11:48 PM
  #6227
Suspended
Trader Rating: 7 (82%+)
has any one try or got pics of theses body shell on there scte 2.0
Pro-Line 2012 Ford Focus ST Rally Body (Clear)
JConcepts Illuzion "Nissan Armada" Short Course Truck Body (Clear)
Pro-Line EVO SC Pre-Cut Body (Clear)
RavensNightFury is offline
Old 02-20-2014, 03:51 AM
  #6228
banana rt's Avatar
im planning to get spring washer to keep my nut locked. is it hex adaptors 12-17mm is a must for solving this problem?
banana rt is offline
Old 02-20-2014, 08:59 AM
  #6229
Default Battery C Ratings
Question for Casper or Ryan, (or anyone else with input)
I see you both are sponsored by Venom for your batteries. The 5800 they have are at a 70C rating. Question is with your experience at what point, if any is overkill in the C category? What I have noticed as the C rating goes up the mAh goes up along with the weight of the battery. While shopping for batteries I have seen the C rating as high as 100.
Has there been any independent comparisons on the batteries that anyone could refer me to?
Looking forward to hearing input.
Ken
SCTE is half way built doing a little bit at a time. Will have it ready for this weekend
Lol currently read up to post 5041 got about 1000 more lots of great info.
PYRO689 is offline
Old 02-20-2014, 09:07 AM
  #6230
Ken
C ratings are measured differently between companies... 4wdSCTs require a lot of C rating from the batteries. whatever brand you go with, make sure they rate that battery to handle the 4wdSCT.
JMURACN is offline
Old 02-20-2014, 01:42 PM
  #6231
jwood7's Avatar
Originally Posted by potatobed409 View Post
I freed up my front sway bars and I'm wondering if that could be it. I went from putting the sway bars into the arm mounts till they where flush with the front. When doing that the short plastic arm was slightly bent back causing a little binding. Now I put them in so the front mounts are pretty much straight up and down threw the entire movement of the front suspension.
If landing hard off a jump to turning 180 degrees could cause the front right to stay under load and retard the rebound of the front left??
I have had the spring retainer cup get pushed over the shock end on a hard impact or landing. Could be the problem
jwood7 is offline
Old 02-21-2014, 08:25 AM
  #6232
Trader Rating: 14 (100%+)
I just switched from Durango to this SCTE and I am in the build process now.
I have acquired a pile ($200+) of good wheel/tires for the Durango but I just remembered that they use that annoying oversized hex.
Do you guys think I could get these to work on the SCTE?
http://www3.towerhobbies.com/cgi-bin...P?I=LXDDEM&P=8
Slippery Dan is offline
Old 02-21-2014, 11:14 AM
  #6233
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
ok upgraded from the stock braces to MIP braces because i snapped the plastic portion like 3 times.... upgrading to KIngheadz center and rear cvd's my question is will theses fit into the center diff outdrives?
Also is anyone running an aftermarket front or rear cvd's?
BlackStarRacing is offline
Old 02-21-2014, 01:02 PM
  #6234
What is the best setup to start out with on this truck?
Old 02-21-2014, 03:09 PM
  #6235
Start with the "latest Dunford setup" on Casper's site. We spent months testing many, many setups, and nothing has been close to this great overall setup. It works most everywhere.
http://www.casper-rc.com/TLR_Ten-SCTE.htm
BSCFlash is offline
Old 02-22-2014, 12:37 PM
  #6236
Default 2mm Spacer
Just confirming that this looks correct?
Using a 2mm spacer under outside ball for the bump steer set up 5/22/13
Ken
PYRO689 is offline
Old 02-22-2014, 02:29 PM
  #6237
maddog9's Avatar
Trader Rating: 29 (100%+)
^^^^that is correct!
maddog9 is offline
Old 02-23-2014, 04:57 AM
  #6238
Ken
Where did you get the spacers? What size are they besides 2mm? Did you need to use longer screws?
Rockarruda is offline
Old 02-23-2014, 07:38 AM
  #6239
Integra's Avatar
Xray sells the shims from their Onroad cars. Lots of these shims are available
Integra is offline
Old 02-23-2014, 09:18 AM
  #6240
Got the spacers from From my LHS amain has them to.Kit comes 1 and 2mm spacers
http://www.amain.com/product_info.ph...cer-Set-TLR-22
Screw length was fine but needed to dremel/drill the inside as it was a little to tight for the screw
PYRO689 is offline
