TLR TEN-SCTE 2.0 Kit Thread >
Like Tree7Likes
Old 05-15-2013, 06:54 PM
  #3796
Trader Rating: 6 (88%+)
I run the s6040 and i run the included screw and nut. how will i get more steering out of it
Rcdudes3475 is offline
Old 05-15-2013, 07:06 PM
  #3797
ta_man's Avatar
Trader Rating: 154 (100%+)
Originally Posted by Rcdudes3475 View Post
What servo horn do you guys use my hits my servo. and I cant get full throw out cuz it hit. it the one from the 22 buggy.
I use Hot Bodies tall servo horns (made out of aluminum).
Part numbers are 67169 for Futaba, 67167 for airtronics. not sure for Hitec.
They only have one hole and are kind of long so I drilled and tapped a new hole to match the length of the stock servo horn. My servo horn can be seen at the right edge of this pic of my 5th body post mount:
ta_man is offline
Old 05-15-2013, 07:20 PM
  #3798
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Hummmm
Originally Posted by CanadianNascar View Post
I have the Orion R8 with Pro 4600, glitches even with firmware update, it needs a bec..
Couldn't wait for the Gen 2...
Glitches like as in your servo or cogging of the ESC?
Originally Posted by Blitzrockey View Post
Hw v3 or 3.1 works awsome!
That's nice.... but I have R10 Pro's
Their firm ware update ?
I've heard a Hobby Wing programmer will work with the Orion also, but don't know which one..
Yes as a link to PC.... I have the Orion Box
Originally Posted by hacker07 View Post
Too bad you don't have a second RX8, they are shipping gen 2's just so you know, haha. In regards to the R10, it needs to be the R10 Pro for starters. Then if you do not have their box to load the 4 pole software which is the best thing to do and in that case you would run the sensor wire, you would run without with the 2 pole software so it doesn't error into sensorless, it just runs that way naturally. Then you will have full power at least.
I just sold my Backup RX8 to ready for the Gen II ... but taking way too long. So I run what I have here... the Orion R10 Pro.... I wanted input from those that run this combo. I here different comments here and there.... but I need input from people with the R10 Pro / Tekin 4600 combo users. I always appreciate all comments though!
Originally Posted by XXXDad View Post
Who Uses the Orion R10/4600 Tekin combo, are there any problems stressing that combo? Are you using sensor wire? I heard you need to run without sensor wire. Or is that some wrong info...
I use the RX8 now and want to move it to my 1/8 scale and drop the R10 in the 2.0
So who has this setup and how's the Temps and Power??
I know to program it I unplug the motor..... but my buddy says he cant run it in Sensor Mode.
I guess I have to find out for myself anyway, and when the White RX8 Gen II finally does come out... believe me I will pop one in for a Ride. But I am an I need it now guy. Thanks again for all your input!
XXXDad is offline
Old 05-15-2013, 08:11 PM
  #3799
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
If you have a S6040 and the correct hardware, nothing should be hitting. Now sure what is going on here, but maybe you can post a photo to show us?
Frank Root is offline
Old 05-15-2013, 08:13 PM
  #3800
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Sorry I ment the esc itself
Blitzrockey is offline
Old 05-15-2013, 08:43 PM
  #3801
Ok so I fixed the issue with the hitting but I still dont have enough steering in the car.
Old 05-15-2013, 09:14 PM
  #3802
TLRacing
Frank Root's Avatar
Check your FB...
Old 05-16-2013, 09:07 AM
  #3803
kingofcool999's Avatar
Sorry if this has been covered already on this thread... but... The outdrives on all three of my diffs are really sloppy. I double checked, they are assembled correctly. Is this a known issue? Anyone else seeing this?
kingofcool999 is offline
Old 05-16-2013, 09:20 AM
  #3804
Purdue Engineer's Avatar
Yes my outdrives move around a lot. They are not leaking and nothing is broke but it sure does feel like the there is something wrong.
Purdue Engineer is offline
Old 05-16-2013, 10:23 AM
  #3805
TCCustoms's Avatar
Yes, there is play and completely normal as stated before....Remember that slop is fast, if its tight, it strains the system, lol
Losi/TLR slop is FAST as most would say
TCCustoms is offline
Old 05-16-2013, 01:15 PM
  #3806
Grandturk's Avatar
Just a little psyched for the weekend -
Grandturk is offline
Old 05-16-2013, 01:17 PM
  #3807
Looks awesome... I'm currently installing a pro4 hd 3500 and the kings head front diff mount ... Stoked!
agarabaghi is offline
Old 05-16-2013, 01:29 PM
  #3808
Quietman_MD's Avatar
Hello all, are their anyone running the STRC Bell Crank in the Losi ten 2.0? If so how do you like it and does it take the slop of the front end?
Quietman_MD is offline
Old 05-16-2013, 02:17 PM
  #3809
Thanks. Getting stoked, going to use my truck in anger for the first time tonite.
  #3810
Casper's Avatar
Trader Rating: 34 (100%+)
Looking good. Even got some retro stickers on there!
Casper is offline
