Like Tree5Likes
Old 11-26-2017, 12:10 PM   #9391
Casper's Avatar
Trader Rating: 34 (100%+)
If I remember right the rods are the same length front and back. The front one uses the two same balls. The rear one uses the round one (no bump) to fit in the upper diff case mount location so depends on if you are making a front rod or a rear rod.
WdotDynamite likes this.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-26-2017, 12:52 PM   #9392
Thanks bud
WdotDynamite is offline   Reply With Quote
Old Yesterday, 11:59 AM   #9393
1fastslash's Avatar
Can someone please provide the specs on the battery tray . I saw a post that said ROAR 2s size with a little wiggle room but that doesnt help since the ROAR website is terrible . Im trying to find a 3s battery that will fit with no modifications. Thanks again .
DRIVE FAST OR GET PASSED !!!
TEAM LOSI , TEAM ASSOCIATED, TRAXXAS
1fastslash is offline   Reply With Quote
Old Yesterday, 01:56 PM   #9394
Casper's Avatar
Basically any Hard case 3S should work. Issue is the battery strap system you use
Team Losi Racing
http://www.tlracing.com/Products/Def...odID=TLR231003
accommodates taller batteries easier
46.7x137.5mm anything very close to this for length and width is fine.
Height 23.1mm is std for a 2S and you can find 3S this big as well. Most 3S are a little taller and can be accommodated with the correct battery hold down.
Old Yesterday, 01:57 PM   #9395
dtr
dtr's Avatar
140*47.5mm, you can go up to about 30mm height with the stock battery posts, but lower is safer. Those posts are easy to replace with longer ones, so height is not a real concern. Too heavy battery can throw the balance off though.
dtr is offline   Reply With Quote
