I need help with a 17.5 t fuse brushless system
Hi I have a traxxas slash 2 wheel drive I was told by a local hobby shop that I could put in a 17.5 t fuse brushless system I just installed it and when I full throttle it it cuts off and then when I let go the throttle and slowly pull it back works fine but when its full throttle it does the same thing I'm running a 8.4 3000 mah traxxas battery please help me I don't know what I'm doing wrong
Ok I will do that but if that still don't work can it be the system malfunction
it could be u never know,but I don't think that's it. but it is always helpful too know what servo and rx you are running ? and is this system sensored or sensorless? also check your esc settings.
It's a sensored system and my radio and receiver is a tqi 2.4ghz
You Have the motor set on kill tone it down and it will work. if you set the timming all the way up it will do it. set it back down till it stops.
Do u think I should go with Lipo maybe there is not enough battery current for system
I have taken it try every setting I even set it to standard setting and still the same
Thanks for everyone help I'm going to try Lipo if that don't work fuse system is just a waste of money
