10% fuel and 20%
Old 04-19-2005, 05:25 PM
onnetz's Avatar
Default 10% fuel and 20%
how much of a difference is there from running 20 and 10% fuel?.
I usually run 20% but screwed up and ended up with a gallon of 10%..
onnetz is offline
Old 04-19-2005, 09:46 PM
WheelNut's Avatar
Basically 10% will just make your engine run a bit hotter and put out less power. So it will be easier to drive, but obviously that is only by virtue of less speed. Yes you will be able to notice a definate decrease in power.
WheelNut is offline
Old 04-22-2005, 07:56 AM
onnetz's Avatar
actually 10% isnt as bad as I thought it would be..
wheelnut I think you got it backwards.. less nitro and more oil = cooler running engine.. unless you lean it out too much trying to make up for the loss of power..
onnetz is offline
