8ight with Tekin rx8 pinion alignment ??? >
Old 01-11-2013, 11:24 PM
Default 8ight with Tekin rx8 pinion alignment ???
Finally got my 8ight conversion done and when I was installing the pinion and noticed that the shaft on the motor doesn't go all the way thru the pinion gear when i was setting the mesh. Is this an issue or is it normal. It can only be installed one way so I'm guessing its normal but thought id askanyway. Also noticed the shaft has a slight bit of play front to back. Is this normal as well? Bought the motor and esc new so I'm hoping I don't have a bad one.
87MagnumII is offline
Old 01-12-2013, 09:54 AM
Trader Rating: 21 (96%+)
It's normal
john stu is offline
Old 01-12-2013, 10:58 AM
Suspended
Trader Rating: 440 (99%+)
Both things are totally normal. Be sure to loctite all metal to metal connections.
MattP is offline
Old 01-12-2013, 11:36 AM
Thanks guys, I just went out for a test run and man this thing is a beast!! Can't wait to get it dialed in
Old 01-12-2013, 11:54 AM
Suspended
Np. What motor and esc are you using?
MattP is offline
Old 01-12-2013, 12:53 PM
Tekin rx8 with 1900kv on 4s
