do you make pit stops in an electric race? >
Old 01-10-2013, 08:24 PM
Default do you make pit stops in an electric race?
what happens if your battery runs out in the middle of a race? does this happen alot? i have a traxxas slash vxl, what class can i go into and what size battery should i use?
14tylbow is offline
Old 01-10-2013, 08:33 PM
microrcdude's Avatar
Trader Rating: 70 (100%+)
Races are 4-8 minutes long, typically without pitstops. Check with your local track regarding their battery rules, some only allow 2c hardcase Lipo packs.
microrcdude is offline
Old 01-10-2013, 08:43 PM
If your track mixes nitro and electric in the same class and the race is longer 8-10 minutes (the main) then they will usually require the electrics to "pit" (stop and go). Essentially it's just to make it fair for the nitro since they have to pit. Most electric cars running lipo/brushless setups will make 15-20 minutes easily.
gte024h is offline
Old 01-10-2013, 09:02 PM
youwish16's Avatar
Trader Rating: 20 (100%+)
when i ran 17.5t sct, i used a 5000mah hard case lipo(http://www.hobbypartz.com/98p-40c-50...-hardcase.html). usually, races are never more than 10 mins.
i still run the same batteries in my ebuggy now(2 x 2s in series)
youwish16 is offline
Old 01-11-2013, 03:45 AM
Pulse_'s Avatar
We did an endurance in electric so we had to, it took about 20 seconds to do the pit stop, everything included. This was in 1/8 scale
Pulse_ is offline
Old 01-11-2013, 03:21 PM
i already have two 5000mah, 8.4v batts, one 3000mah batt and two chargers for them. do i have to buy a lipo batt and a lipo charger if i ever want to race?
14tylbow is offline
