Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-23-2014, 07:04 PM
  #12406
bigcracing's Avatar
Trader Rating: 32 (100%+)
Don't forget RPM ball cups stock ones break
bigcracing is offline
Old 02-23-2014, 07:45 PM
  #12407
So standard to switch them out I forgot
lee111m is offline
Old 02-24-2014, 08:54 AM
  #12408
the incubus's Avatar
Trader Rating: 17 (100%+)
While most people will swear by them, I find RPM cups wear out and become too loose too quickly, and while they may not break, some of them tend to pop off. This is why I changed all my hardware to TLR Cups and studs all around. They are much more precise than any other cups in the industry (same as the Kyosho I believe) and are extremely durable. They take a long time to develop any sort of slop and only then through repeated abuse. That is what I do on all my cars.
the incubus is offline
Old 02-26-2014, 07:07 AM
  #12409
clw
Just picked up a 4.2. Been away from RC for over 10 years and recently broke out the old XXX buggy and T3.
The 4.2 is setup with 1.6 pistons and front white and rear green springs. Our local track is an outdoor clay track with some fairly big jumps. Surface smooth to choppy that gets dusty (sandy) as it breaks down.
Can someone point me to a good starting setup? I'm a club hack until I get all my skills back meaning I'm not the best at hitting the down ramps of the jumps. The setups I see on RC10.com are almost all indoor high-bite.
clw is offline
Old 02-26-2014, 07:08 AM
  #12410
clw
clw is offline
Old 02-26-2014, 08:27 AM
  #12411
JeepnMike's Avatar
http://www.petitrc.com/setup/associa...dRC10B4.1.html
JeepnMike is offline
Old 02-26-2014, 08:40 AM
  #12412
1967Typhoon's Avatar
Trader Rating: 35 (100%+)
I would put "standard" setup from the Ray Munday setup chart.
http://www.petitrc.com/setup/associa...hart201401.pdf
This chart is worth printing out and putting in your toolbox, or saving to your smartphone. It is spot on.
1967Typhoon is offline
Old 02-26-2014, 08:47 AM
  #12413
clw
JeepnMike
That link leads to the 4.1 version. Do the same setups work between the 4.1 and the 4.2? I thought the 4.2 was unique with the new 12mm shocks.
clw is offline
Old 02-26-2014, 09:15 AM
  #12414
JeepnMike
Just use the chart I sent. It is made by a very, very knowledgeable racer and team driver for AE. That standard setup should be a VERY good starting setup for you.
Old 02-26-2014, 09:22 AM
  #12415
clw
I didn't understand the chart at first, I thought the standard seyup was the kit setup, not his evolved standard!
That's quite the chart, I can see why you'd just use it as a reference as track conditions change. Means a bunch of changes to what came in the mail. That's OK, I'd rather start at a known point and learn to drive from there.
When he states oil weight that's referenced to Lucas silicone, right?
clw is offline
Old 02-26-2014, 10:00 AM
  #12416
He is using the Team Associated shock oil, available just about everywhere.
http://www.amain.com/product_info.ph...k-Oil-30wt-2oz
Old 02-26-2014, 10:07 AM
  #12417
JeepnMike's Avatar
JeepnMike
Sorry, 4.2 here as well as any other car really, this is the mecca for setups:
http://www.petitrc.com/_forumphp/sheet.php
Old 02-26-2014, 10:21 AM
  #12418
clw
Yup, I thought that was a Lucas product, my bad.
thanks
clw is offline
Old 02-26-2014, 11:09 AM
  #12419
mxnickj's Avatar
Trader Rating: 51 (100%+)
thanks
The AE oils have the Lucas Oil logos on the bottle. I'm not 100% sure of the connection there but either way, its all the same oil
mxnickj is offline
Old 03-01-2014, 10:25 AM
  #12420
ecpete's Avatar
Trader Rating: 39 (100%+)
Subscribed
ecpete is offline
