Old 04-16-2005, 10:33 AM   #16
Nick111's Avatar
Send a message via AIM to Nick111
No problem, that setup I gave you will get you started on the right track. Currently at LIR all im doing to my tires is coating the inside with motor spray, mounting with uncut glued together B2, and zip freeing them 30 minutes before heat, without scrubbing it in. I'll be racing the season opener tomorrow at RC Madness, will you be there? I'll be racing Mod Buggy and Mod Truck, I'd race 4wd like im going to at the Nats but 4wd + new track = bad decision
www.BIGjohnsonpaints.webs.com
Nick111 is offline   Reply With Quote
Old 04-16-2005, 08:59 PM   #17
thedoc329's Avatar
yea im goin, runnin mod truck and gas truck ill be there around 8, some guys run 4wd once and awile, but i think its usually a group of buddys that love mod 4wd
thedoc329 is offline   Reply With Quote
Old 04-18-2005, 08:28 AM   #18
Nick111's Avatar
I ended up only running Mod buggy, since my truck receivver decided it doesnt like mud. I have to say, even though the layout was more for 1/8 scales, it was still a fun track. I still dont understand why they didnt sweep the track before they wet it.... or why they wet it why people were running on it every 5 seconds. but after bad qualifying i started 8th in the A and finished 3rd.. not to bad, LIR took 2,3 and 4 not sure how we did in truck.
To get back on subject, while i was there I ran red 7204s, I had cut the outer rib off to get some more turning, I didnt think it would work on a low bite but suprisingly it did.
Old 04-19-2005, 10:17 AM   #19
I heard belt dressing works crazy. Heard it makes the tires super tacky. But the trick is to find the right kind, and leavin it on there for about 30 min before you run them each time. The main thing I can think of as pre-treatment is to get the oily feel out of the tires. Hence the wd40, motor spray, etc. I like simple green.
runnin rc10 is offline   Reply With Quote
Old 04-19-2005, 10:32 AM   #20
Driver1's Avatar
Send a message via AIM to Driver1
WD40 in the SH!T on alot of surfaces
Driver1 is offline   Reply With Quote
Old 04-19-2005, 10:52 PM   #21
arghh's Avatar
is using combination tyre for front and rear is good...?? the curve type infront for cornering and flat type inrear to get traction / accelerate
arghh is offline   Reply With Quote
Old 04-20-2005, 09:16 PM   #22
thedoc329's Avatar
ive seen alot of guys do it, ive tried it but dont care for it, i'd rather take some dual rate out than have it push, but i guess it depends on what you like
Old 04-21-2005, 06:23 PM   #23
on gas trucks, is their a way to stop the tire from inflating(looking like its gonna come off the rim) when running down the straighaway, or reving really high?????????
D Mac is offline   Reply With Quote
Old 04-21-2005, 08:47 PM   #24
Tech Legend
Wild Cherry's Avatar
Belt the inside of the tire with duct tape ...
Bout 1" wide strip should do..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-23-2005, 02:12 PM   #25
beetlebz's Avatar
Send a message via AIM to beetlebz
so youre THE proctor eh? Hi Mark
i guess its a small virtual world after all!
Its rare that I find myself looking for more traction than a soft set of hole-shots or step pins will provide, but I have used paragon with success in the past. you just need to let it soak in for a while.
Im going to belt my next pair of step pins, Ill let you know how it works.
I cant really confidently throw around my $.02, because I wont find out until opening day at Xtreme if you guys will blow my doors off or not
beetlebz is offline   Reply With Quote
Old 04-23-2005, 09:52 PM   #26
thedoc329's Avatar
well be there, not sure for opening day, but looking forward to coming down either way. ive been racing a few big races lately and have noticed alot of weird tire work going on in other states, mostly VERY hard packed tracks, and was interested to see what other people do to there tires in other regions besides our new england, becuase god knows we can go from step pins to holeshots with the change of the clouds!!
Old 04-24-2005, 12:02 AM   #27
beetlebz's Avatar
I raced up north a few times (new hampshire) and for some reason they LOVE really hard dirt, and one of them (a back yard track) was sprayed with sugar water. holy traction batman....
most everyone else used sway bars and stiff springs. I ran my usual set up with 10wt thicker oil all around and the soft compound hole shots. I had to be careful not to roll over in the corners, but holy crap that thing was a missle. with one step up in springs I would have been untouchable. the downside, is after two runs, I was running on slicks lol
Old 04-27-2005, 04:47 AM   #28
Send a message via ICQ to elvo
I've successfully belted tires with fishing wire and a needle. Takes time though :-s I'm not sure it's worth the effort, I think finding a solution to stop the sidewall from folding all over itself is worth more.
more tips and tricks: http://users.pandora.be/elvo/cols/ort/index.htm
elvo is offline   Reply With Quote
Old 04-27-2005, 07:41 AM   #29
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
FYI: belting off-road tires & ROAR don't go together....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 04-28-2005, 09:56 PM   #30
Phroziac's Avatar
Send a message via AIM to Phroziac Send a message via Yahoo to Phroziac
Default About worn tures...
Worn out tires are great for making slcks! Make sure they don't have any holes, then use a sandpaper drum on a dremel to remove the rest of the tread.
Phroziac is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
MARCCA Outdoor Offroad Track (Rockpile) Summer "05" Rock Pile MARCCA Discussion 162 12-24-2005 07:36 PM
