Yokomo B-MAX2 MR/RS
Old 01-10-2015, 10:04 PM
  #2056
NoobRCDriver's Avatar
Anyone tried the Exotek direct spur mount? I know they don't have one just for the yok but didn't know if another would fit.
NoobRCDriver is offline
Old 01-10-2015, 10:13 PM
  #2057
WillS's Avatar
Trader Rating: 31 (100%+)
I run an Avid Kyosho topshaft and run the avid triad slipper on the car. For $8 or something like that, you can swap between the slipper and a lockout from Schelle. If you are interested in running the kyosho topshaft refer to the first page and it has the how-to on putting in the kyosho topshaft to run the amazing triad/nova slipper setups.
WillS is offline
Old 01-10-2015, 10:58 PM
  #2058
Thanks for the reply. I just bought/installed the Yok alu. topshaft. I don't want to pay $40 for the Schelle. I'm giving stock a try and want to keep the cost down as much as possible.
Old 01-11-2015, 02:23 PM
  #2059
There will be a shipment that comes in on monday from what I hear. If you backorder it (free of charge) there is a great possibility that you will get it reserved if there are some in that order.
Thanks Will.... That is correct, we will have a shipment coming in bright and early.
nitrorush27 is offline
Old 01-14-2015, 10:51 AM
  #2060
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by fatbear View Post
What open cell insert do these pre-mount tires come with?
Originally Posted by MarkA View Post
They should be the ones listed here: http://eos.redrc.net/2014/09/schumac...-eos-season-4/ as they're acutally meant to be the EOS' handout tires.
I picked up a set yesterday and can confirm that they are in fact, those blue ones.
The fronts are particularly well-done. No more trimming rims and then trying to hope you get enough, but not too much, glue in there.
MarkA is offline
Old 01-14-2015, 12:22 PM
  #2061
WillS's Avatar
I found a company that can turn our stock ball diff outdrives into lightened outdrives. Total weight of the 2 would be 17ish grams. I am looking at interest and have an email to find out how many sets to consider a run for him. This will help out us stock guys tremendously. Going to try and sneak in some wheeler ones to see if he will do them for when I go to stock nats.
WillS is offline
Old 01-15-2015, 11:39 AM
  #2062
Will, im in for sure.
Old 01-15-2015, 11:56 AM
  #2063
mes
If only these were available with yellow wheels...
mes is offline
Old 01-16-2015, 12:15 AM
  #2064
roger999's Avatar
Guys, what servo saver u using instead of kit ones? Or kit one works just fine?
I was trying to use TC servo saver, lasted only one race
Have on order original yoko but found that is not so great, is that true?
I bought used car so didnt get any servo saver with it just solid horn, dont really want to damage my servo...
roger999 is offline
Old 01-16-2015, 04:51 AM
  #2065
mes
The original one is ok, but I switched to an aluminum servohorn. Meanwhile Arrowmax offer a servohorn with dimensions identical to the kit servo saver.
AM-MAX2-009...010...011
mes is offline
Old 01-16-2015, 06:53 AM
  #2066
roger999's Avatar
Thanks for reply, i know there is arrowmax servo horn but i asked about servo saver not solid servo horn...
roger999 is offline
Old 01-16-2015, 07:45 AM
  #2067
303slowdown's Avatar
Trader Rating: 24 (100%+)
I'm use the stock servo saver and it works just fine , if just check it every few races to make sure it's still tight.
303slowdown is offline
Old 01-16-2015, 09:43 AM
  #2068
roger999's Avatar
ah great so dont need to worry about! cheers
roger999 is offline
Old 01-16-2015, 10:26 AM
  #2069
Moderator
MarkA's Avatar
You'll want to just threadlock the screw going into the servo. Solves everything and yeah, the stock part is fine.
MarkA is offline
Old 01-16-2015, 11:25 AM
  #2070
WillS's Avatar
The new YZ steering parts offer a solid servo horn for the bmax2. You can look into that. I run AE b5 one on my car with no problems.
WillS is offline
