Slash 4x4 vxl esc with crawler motor questions >
Old 12-21-2012, 07:34 PM
Brandonmorris44's Avatar
Trader Rating: 34 (100%+)
Default Slash 4x4 vxl esc with crawler motor questions
I recently purchased a slash 4x4 offline and it came with a vxl 3s esc and a 18.5 sensored based Novak
Brushless motor . And 3 lipo battery's . I am just wondering if I should put stock velineon motor on it or
What motor I should install if this is not good . I am not going to race thi truck probably just ply around in
driveway and lightly bash .thanks
Brandonmorris44 is offline
Old 12-21-2012, 08:06 PM
HobbytownGBW's Avatar
Running a novak sensored motor is going to be a better motor than a stock velineon motor. That being said, the 18.5 is going to be a significantly lower RPM motor. What voltage are the lipos you got? 3s packs would probably make that truck run quite well, but 2s packs would probably be a little slow on the top.
HobbytownGBW is offline
Old 12-22-2012, 04:24 AM
2200 mah - sky lipo . Should I run a certain gearing setup with that motor
Old 12-22-2012, 04:42 AM
Devigili22's Avatar
Trader Rating: 29 (97%+)
How many cells?
Devigili22 is offline
Old 12-22-2012, 05:23 AM
Well I have a venom 3s 11.1v 5400 mah that I will probably run in it some but I'm not sure how many cells those sky lipo batteries are ill have to check later
Old 12-22-2012, 07:08 AM
that traxxas motor will be much faster, and probably a lot more reliable than the novak..
getloose is offline
Old 12-22-2012, 09:28 AM
Oh ok the guy up top said the crawler was faster . The truck came with 3 cell 11.1 40c continuos burst 2200 mah sky lipo ultimate charge series. If you feel like the crawler Novak is slower and less reliable what motor do you recommend I install
Old 12-23-2012, 06:39 PM
th crawler motor is most likely an 18.5t. maybe 2500ish kv. the traxxas is a 3500kv 10t its much faster... just run that. they are solid motors
getloose is offline
Old 12-23-2012, 07:43 PM
Yea well I guess I will remove the crawler would you say I need to buy a stock velineon motor or order like a viper or tekin something like that
Old 12-24-2012, 01:27 PM
if you plan on just running it around your house, the velineon motor is perfect. viper and tekin motors are fast, but a bit more delicate.
getloose is offline
