eliminating e-clips >
eliminating e-clips
eliminating e-clips
Old 04-09-2005, 12:04 AM
BOWTIE1's Avatar
Default eliminating e-clips
i been working on eliminating e-clips on my xxx-nt ... gt sick and tired of them popping off or braking a a-arm and the sho gue don't have time to dry by your next race....they ain't fiinished yet still in testing and getting everytng down perfect..... here is 2 pic's of that they look like but they ain't done enjoy and if any1 wants some u can e-mail me at [email protected] for more info on them thanks sorry fr the crappy pic's ill try to get better pic's
BOWTIE1 is offline
Old 04-09-2005, 07:38 AM
Scrad's Avatar
Trader Rating: 16 (100%+)
That truck looks familiar You could also use the traxxas hinge pins. I used them on my lxt a long time ago. They screw into the plastic. But that truck has the lunsford pins, so I'd keep those in it.
Scrad is offline
Old 04-09-2005, 09:03 AM
BOWTIE1's Avatar
Scrad
ok kool
BOWTIE1 is offline
Old 04-12-2005, 05:14 PM
Trader Rating: 28 (100%+)
I can't tell by the pics, what exactly did you do there?
jbrow1 is offline
Old 04-21-2005, 02:02 PM
17driver's Avatar
I would like to know what you did also.
17driver is offline
Old 04-22-2005, 05:20 PM
BOWTIE1's Avatar
i tool a ti rod cut it down and threded it on both ends it works gr8 aitn broke 1 or bent it yet
BOWTIE1 is offline
Old 04-22-2005, 06:27 PM
nimble's Avatar
I also can't stand having these E-clips on my XXX-T, the B4 has a captured pin, Associated must have a patent on it..
It has been suggested to me that I can add a set-screw to the arms, and flatten out the pin at the spot the screw comes in. The set screw then hold the pin in place, no e-clips. Sounds good, haven't had time to do it yet.
What I'd also like is something to eliminate the body clips as well, those are also a pain.
nimble is offline
Old 04-23-2005, 09:47 AM
Nick111's Avatar
Since you guys have XXX-Ts, you could also try the XXX-4 hinge pin screws where ever the hole is 3/32.
Nick111 is offline
Old 04-23-2005, 11:39 AM
nimble's Avatar
I have a XXX-4 also, but haven't been racing it, I'll take a closer look at it, do you mean the front area where the arms meet/connect, there is a hinge pin screws that hold the pins in? this can be used on the XXX-T?
nimble is offline
Old 04-23-2005, 02:41 PM
BOWTIE1's Avatar
mine would work on a xxx-4
BOWTIE1 is offline
Old 04-23-2005, 02:46 PM
Nick111's Avatar
I'm not 100% sure, the threaded area might be too big, but you could always space it out some. I will try it right now and see.
*edit* Nope , It doesn't work. The XXX-4 Hinge hole must by smaller than 3/32 bedcause the screw is to small to fit.
Nick111 is offline
