Hobbico CS-170 or better? >
Old 12-03-2012, 11:53 PM
LGWGM's Avatar
Default Hyperion EOS 0720i NET3 AD or better?
Hi guys, I'm on the search for a good AC/DC charger (again) and am currently looking at the Hyperion EOS 0720i NET3 AD ($120+) but before I pull the trigger, I would like to see what are the majority here think?
Goal:
* Still not comfortable with the DC charger + 12V power supply
* Need 1 - 2 charging ports only
* Price range $50 - $150 (could stretch to $200 if needed be)
* To charge 7.4v 5000mAh NiMh & 2S 5000mAh LiPo (wont be using higher than 2S LiPo unless I go BL)
Is it true these chargers aren't reliable, i.e., power adapter failure, can't balance charge properly, etc...?
Venom Pro charger
Imax B6-AC
Thunder AC-6
LGWGM is offline
Old 12-04-2012, 12:54 AM
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
what do chargers have to do with a hobbico servo?
RC*PHREAK is offline
Old 12-04-2012, 04:37 AM
Stubbs's Avatar
Trader Rating: 58 (100%+)
That's what I was thinking...
By the way, to the OP, it's a 2S Lipo, not "2C".
The C-rating refers to the discharge rate (i.e. "punch" of the battery), or the charge rate (i.e. 1C on a 5000mAh pack = 5A, 2C = 10A, etc.....)
Stubbs is offline
Old 12-04-2012, 07:09 AM
LGWGM's Avatar
Okay guys.. really sorry for the confusion
Too busy searching multiple things at once and no sleep so here I am messed up
LGWGM is offline
Old 12-04-2012, 07:31 AM
kcooper273's Avatar
Trader Rating: 54 (100%+)
If you are only going to be charging 2S batteries, take a look at the Hyperion 0606i. I have that, very happy with it, and it is much cheaper than the 720. It can handle 4S, it just takes a longer time.
kcooper273 is offline
Old 12-04-2012, 12:23 PM
LGWGM's Avatar
Thanks for sharing
Its either 720 or any of those chargers mentioned on first post if they are any good
Anyone got some input for those 3 chargers mentioned above?
LGWGM is offline
