Metal Spur gears
For those of you running spur gears in Truggies what brand are you using? I was going to use Losi's 45T for my 8T.
Use the stock spur from your manual. There's probably a couple different gear selections available if you need to go way outside of the norm for whatever reason but stock tooth count is usually best and go up or down on your pinion tooth count to change gearing.
I'm using the losi 45T. I'm happy with it. It's loud as hell but it works.
Isn't a 45t spur a bit low for a Losi truggy? That is the default spur that comes with the 8ight-e buggy. I would think something like a 48 would be more appropriate.
