Slash 2wd Vxl esc help!! >
Old 11-15-2012, 09:10 PM
Default Slash 2wd Vxl esc help!!
Hey guys having some trouble with my slash 2wd brushless, has the vxl in it.
Couple weeks ago iI cracked the chassis while jumping her so i ordered a new one replaced it best kind was running 2s at the time. SO decided to try 3s and after fixing the chassis and charging the battery hooked up the 3s lipo and she won't go in reverse, the ESC starting smoking when I held reverse and also she will go forward at about 70% for 30seconds or so and then she stops and will barely move at this point the ESC is flashing red but the lipo isn't dead, steering is fine. Is it fried?
WIll traxxas replace it? Or should I just buy another? I'm almost positive the motor is fine.
Been looking into the hobby king Ez Run but am not positive on which way to go about this..
stone202 is offline
Old 11-15-2012, 09:52 PM
If it started smoking it's probably "done." Check reprogramming the ESC and make sure the lipo cutoff is ON. If that doesn't work, I'd contact Traxxas and see if they'll replace. Also I know that VXL's don't like 3s too well. I know as I have 3 of them. Been running w/2s w/no problem and changed gearing. I went w/Castle 3800 and it is a BIG difference and can handle 3s.
bowl806 is offline
Old 11-16-2012, 10:44 PM
WHats your gearing on your slash? and yeah i ordered a hobby wing 120A brushless esc, which id rated for up to 4s, so 3s should be fine i'm hoping.
stone202 is offline
Old 11-17-2012, 09:56 AM
30/76 but sometimes 26/86
bowl806 is offline
Old 11-17-2012, 10:06 AM
lbenton's Avatar
Trader Rating: 48 (100%+)
Traxxas may replace it... call them to see.
Once you let the smoke out you can not put it back. The esc is done.
lbenton is offline
Old 11-17-2012, 01:33 PM
HPI-Blitz 101's Avatar
Trader Rating: 122 (100%+)
I think they will replace it for $90.00 if you send it in for the system or like $40.00 or $50.00 for the Esc.
HPI-Blitz 101 is offline
Old 11-17-2012, 09:51 PM
Okay thanks.
Something I noticed as wel before i encountered the esc trouble was that at low speed(when wheels aren't touching a surface) only the right back wheel will spin and the left one doesn't start spinning until about 3/4 throttle...
I'm guessing something is loose, or wore but am unsure as to what it is, any help ?
stone202 is offline
Old 11-17-2012, 10:01 PM
Devigili22's Avatar
Trader Rating: 29 (97%+)
Okay thanks.
That's either something going on in your diff or there is some serious binding on that wheel.
Devigili22 is offline
Old 11-17-2012, 10:05 PM
Okay thanks.
Did you notice any power loss in the system before it blew?
Old 11-18-2012, 10:16 AM
Ahh cant really say for sure because before i broke the chassis I was running 2s lipo and then after replacing the chassis i tried running a 3s and she seemed fine for a couple minutes without reverse, never got to see the full potential of 3s so not really sure about that. She was very fast though which i assume she shouldve been
stone202 is offline
Old 11-18-2012, 10:56 AM
Mine did the same thing I believe no reverse then blew..I was only running NMH though..
Just throw in a MMP instead.
Old 11-18-2012, 12:38 PM
MMP? Mamba monster pro? I bought the hobby wing 120A 2-4 eac for her.
stone202 is offline
Old 11-18-2012, 12:43 PM
I meant the Mamba max pro but,Hobby Wing should be okay.I bought the 60a for my LIL Brother This year and he has raced and Bashed with it in his Slash and its still holding up..
Old 11-18-2012, 01:39 PM
okay gotcha.
stone202 is offline
Old 11-18-2012, 01:40 PM
How would i go to check this ?
stone202 is offline
