LRP ix8 problem
i currently run a LRP ix8 paired with a LRP 2200 Dynamic 8. lately, i have been having problems with it cutting off. it started with jumps, then small jumps, not it just cuts on straights. sometimes only at 1/4 or 1/2 throttle. the switch has been cut off. and once it stops, you can unplug and plug the battery, and it works fine until it quits again.
car: Rc8e.2 ESc: Lrp Ix8 Motor: Dynamic 8 2200kv Battery: Reedy 4s 60c 5500mah with EC5 connector Servo: Savox 1283 with novak cap radio: Ko Propo was Spektrum dx3r pro (cut off on both radios) LVC is at 6v and overheat is on. it made 2 laps saturday in the mains on a 23 sec lap track typical is 26-28 sec lap...so that gives you an idea any input would be great before is send this thing back to LRP for repair!! thanks daniel |
you might try looking through this thread http://www.rctech.net/forum/radio-el...9-lrp-ix8.html . Maybe something in there might help.
Any luck in solving your problem?
| All times are GMT -7. It is currently 08:39 AM. |
