allen keys
Old 03-30-2005, 11:20 AM
Default allen keys
i'm trying to take apart my RTR B4, and when I tried to take a screw off with the allen key it kinda got stripped and I didn't even turn it or force it. Now I can't take of my rear shock tower. HELP!!
takwing is offline
Old 03-30-2005, 11:29 AM
Buy a set of allen drivers. Problem solved.
Drewp is offline
Old 03-30-2005, 12:35 PM
DJ_Normal's Avatar
Integy Ti-Nitride hex drivers. Get them and you'll have a new best friend. Trust me.
DJ_Normal is offline
Old 03-30-2005, 07:45 PM
Suspended
Location: please try not to look at my avatar to long may cause u know what
i think waht hes trying yo say is that the bolts are stripped drillm out thats the only way
andy_666 is offline
Old 03-30-2005, 08:01 PM
you can also use a dremel and cut a flathead slot into them to get them out
jswinkos is offline
Old 03-30-2005, 11:20 PM
DJ_Normal's Avatar
Even if that is the case, a good set of hex drivers will keep it from happening again.
Old 04-01-2005, 05:10 PM
Trader Rating: 22 (100%+)
If it is the wrench then mip/thorp makes a great wrench also hudy tools are very good.
If it is the screw here is some tips for removal I have found online.
Drill small pilot hole then tap with left hand thread (reverse)
Heat screw to expand metal. thread lock releases at 300 degrees
Glue wrench to screw
Dremel slot to allow use of a standard screwdriver
Ez out screw remover bit
Small flat head screwdriver in hex slot
SODER WRENCH TO SCREW
Put hex driver at 45 degree angle and turn slowly. Once out enough grab with pliers.
cmain is offline
Old 04-02-2005, 09:54 PM
once youve stripped the screw soldering the wrench to the screw, using the wrench at a 45 degree wont work. either get a left hand screw of dremel a slot. glue most likely wont work. never seen a glue which would hold the twisting of about the diameter of a couple millimeters.
greencactus3 is offline
Old 04-02-2005, 10:31 PM
BritRacer's Avatar
all the screws on the B$ are hex head and stick out.
Take some pliers...grab it and twist it till it comes out. you may need to use a file to make a slightly flat edge.
BritRacer is offline
