Old 03-28-2005, 02:57 PM   #1
HaLo_UsMc's Avatar
Send a message via AIM to HaLo_UsMc
Default how to change the deans
i was wondering how do i change my tamiya connectors to deans???
HaLo_UsMc is offline   Reply With Quote
Old 03-28-2005, 04:34 PM   #2
Trader Rating: 28 (100%+)
First buy the deans connectors. Then cut the tamiya plugs off. Solder on the new deans, making sure polarity is all matching from plug to plug, then shrink wrap the solder joints.
You want the female part of the deans plug on the battery, and also a female on the esc where it goes to the motor if you use plugs between the motor and esc. This helps prevent shorting out the battery and esc.
jbrow1 is offline   Reply With Quote
Old 03-28-2005, 10:31 PM   #3
DrOlds's Avatar
When you solder on Deans plugs make sure and have them "plugged in"(both halves together).They distort very easily and having the other half on there keeps them aligned so they wont be hard to plug in when you are done.I always put the pos on the fat side and the neg on the skinny side.
DrOlds is offline   Reply With Quote
Old 03-28-2005, 10:59 PM   #4
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Olds, that's friggin brilliant, I never once thought of that.
go the old rocket
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 03-28-2005, 11:05 PM   #5
DrOlds's Avatar
Thanks! (I did learn that the hard way )
Old 03-28-2005, 11:07 PM   #6
DrOlds, thanks for the tip!!!
Old 03-29-2005, 07:02 AM   #7
nwilcox88's Avatar
Olds is correct... And add to that... Do one post let it cool then do the other post because the heat WILL ransfer through out the whole little plug. Take you time with this, you will thank yourself later. It is not a race to get them done the quickest.
nwilcox88 is offline   Reply With Quote
Old 03-30-2005, 05:54 PM   #8
t4usee's Avatar
go the old rocket
I agree,,, that is an awsome idea!!!
Team Tekin
Team Fusion
BKPaintwerks.com
t4usee is offline   Reply With Quote
Old 03-30-2005, 06:34 PM   #9
HaLo_UsMc's Avatar
thanks everyone im afraid i cant do it so im going to get my local lhs to do it then ill watch them. inless anyone knows where i could get a video on it.
Old 03-30-2005, 06:39 PM   #10
Do you have a soldering iron? And know how to solder? If not ask the hobby shop guys if you can watch them when they do it solely for the reason of learning how. I don't know of any videos, but if you got the the magazine Extreme Rc and search, I think they have an article how to of "How to solder like a pro."
Old 03-31-2005, 01:58 PM   #11
HaLo_UsMc's Avatar
i know howto solder i got a soldering gun and solder i dont wanna mess it up though.
Old 03-31-2005, 02:04 PM   #12
nwilcox88's Avatar
It is easy to do, the only thing is you just need to be patient with it. For best results take it one step at a time.
Also something else that I dont think anyone mentioned.. When you cut old battery connector's off. DO NOT cut them at the same time, do them one by one. If you cut them togethor you could short the pack out. I suggest not stripping the ends until you need to use that wire as well.
Old 04-02-2005, 10:58 PM   #13
Send a message via AIM to greencactus3
i recommend getting an iron. guns are clumsy and dont have quite enough mass at the tip to hold its heat very much.
greencactus3 is offline   Reply With Quote
Old 04-02-2005, 11:04 PM   #14
HaLo_UsMc's Avatar
lol it looks like when you solder motor leds to a motor!!
Old 04-03-2005, 04:11 AM   #15
Aaron Waldron's Avatar
Make sure that when you cut the old plugs off of your batteries, you snip the wires one at a time. You wouldn't want to short something like that out....
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Serpent starter box,Deans discharger,Deans battery jig,Indi battery equalizer SRAD R/C Items: For Sale/Trade 5 03-14-2007 05:32 PM
how to deans? cazato Rookie Zone 3 04-05-2006 08:47 PM
what do you change up first. Fantomcat Electric On-Road 7 01-30-2006 07:37 PM
How can i change me name? Brett.w R/C Tech Site Forum 6 09-28-2004 02:45 AM
Help with Deans dimples Rookie Zone 3 01-08-2004 09:33 AM
