HPI VORZA spur gear
Old 11-02-2012, 05:51 PM
Default HPI VORZA spur gear
anyone try this gears or hear about FLY RATIO vorza gears
i saw them sold on Ebay ,35T SPUR , 25T PINION
are these gears useful
vin200 is offline
Old 11-15-2012, 05:41 AM
Anyone have idea about them Pls!!!
vin200 is offline
Old 11-15-2012, 03:46 PM
LowBudgetRacer's Avatar
Trader Rating: 22 (100%+)
A 25 tooth pinion is huge. Way to big. Go with something in 17 tooth range. The Losi eight spurs fit the vorza.
LowBudgetRacer is offline
Old 01-25-2013, 06:20 PM
Hey i just installed that gearing on my vorza.
it insanely fast.. just what i wanted my vorza to do for speed runs
but if your not planning for speed runs and straight lines this is not for you
it is super over geared and will get very hot very fast
traveling at 60 mph/ 100 kph from 1/4 to 1/2 throttle it will flip the car
but if you are planning to get it installed make sure you take it easy from start.. do not launch it from stop position .. and what your TEMP!
i had to file down the spur gear to fit the ball bearing with a little help with my hammer it was a tight fit but that ball bearing aint coming out .. so i recommend you purchase an extra ball bearing for the original spur gear
hope this helps
Tir33X is offline
