Like Tree129Likes
Xray XB4 thread
Old 02-06-2019, 08:32 AM
  #13051
offroad dude's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Maraach View Post
I'm not sure this is correct. Pretty sure the AE rear rim and xb4 rear rims are the same. The fronts is where they differ.
At least that's what the proline support guys told me and ty tessman runs 2736-04 as his rears
So, what do we need to do to run AE front rims?
offroad dude is offline
Old 02-06-2019, 08:37 AM
  #13052
2 strip fronts, 3 strips rear, or so I was told a few months back.
I did try my B64 wheels on a friends Ď19 spec car, there was a small, but noticeable difference between the AE & kit wheels.
John Myall is offline
Old 02-06-2019, 09:04 AM
  #13053
Would you happen to have the part numbers.
Old 02-06-2019, 03:35 PM
  #13054
I think itís these, XR365356 for the 2 strip, XR365357, for the 3 strips. I didnít go for the XB4 in the end, so didnít need to buy any hexes.
Old 02-07-2019, 12:35 PM
  #13055
Honestly I could never work it out. I ended up just keeping my as rears and getting the proline xb4 fronts.
I'm really curious to hear the end of This as well. All I've been told to date is that rears are standard but fronts differ. I would be surprised if rear needed 3 stripe to work but let me know how you go.
offroad dude likes this.
Maraach is offline
Old 02-10-2019, 01:15 AM
  #13056
Default Xb4 front arms
Hi I have my xb4 for a year and really like how it drives. The only problem I have is the front arms, I have broken about 6 arms. Tried medium and hard with same result, Do you guys think the graphite arms is stronger?
stinger84 is offline
Old 02-10-2019, 08:14 AM
  #13057
Pville Stig's Avatar
The Medium arm is the most durable. Graphite is more brittle and easier to break.
rippen likes this.
Pville Stig is offline
Old 02-11-2019, 07:18 AM
  #13058
I am a newb and i have been running a 18 xb4 and just ordered a 19 and tips on the build? Thanks
Lucky777 is offline
Old 02-11-2019, 09:27 AM
  #13059
Zerodefect's Avatar
Use cap head screws on the bulk heads, and MIP SAE drivers.
Zerodefect is offline
Old 02-11-2019, 09:33 AM
  #13060
MIP tools check and thanks
Lucky777 is offline
Old 02-12-2019, 11:33 AM
  #13061
snwchris's Avatar
Just started running 13.5 class with the XB4 and using Reds 13.5 motor with 30* can timing and HW V2.1 ESC and running 81/24 gearing.
This past weekend, felt like I was being pulled on the straight on the track (60'-75') by a couple guys and cars looked like MOD in the 13.5 class, LOL
I have a 78 spur I'm thinking about trying to see if that will help get some speed and trying to figure out pinion gear either 24 or 25 and if should also turn up timing on the motor can.
Chris
snwchris is offline
Old 02-12-2019, 11:43 AM
  #13062
Chris
I don't know anything about the Reds motor. But 30* of timing and gearing at 81/24 seems really low to me. What temp is your motor coming off the track at?
I run a Reedy S + 13.5 and my timing is 37* and I am geared at 78/26 and the buggy is as fast as any other on the track. If the Reds motor is high rpm like the Reedy you might want to try this to start and check temps.
Kelseyrc is offline
Old 02-12-2019, 01:33 PM
  #13063
snwchris's Avatar
I have a 16 XB4 that I've been running for 3 yrs now and have only broken 3 arms.
Either your crashing alot and need to slow down or run cleaner or something in the suspension is binding causing unusual amount of broken arms.
snwchris is offline
Old 02-12-2019, 01:34 PM
  #13064
snwchris's Avatar
Thanks will try that out.
This past weekend it was temping out at 158* with a fan behind the motor.
snwchris is offline
Old 02-12-2019, 02:20 PM
  #13065
That seems really hot based on your gearing. With my setup the Reedy only gets up to around 135*. Have you checked to see if anything is binding in your drivetrain?
Kelseyrc is offline
