Like Tree134Likes
Xray XB4 thread
Old 03-09-2018, 06:50 AM
  #12856
crusty's Avatar
hi there
i have a 2018 xb4 and have been studying setup sheets
i run outdoor low traction largish track fairly big jumps 6.5 motor
two questions do people use a front lower brace and upper steering brace in these conditions?
also what droop is a good start. , setups vary alot on the setup sheets
crusty is offline
Old 03-09-2018, 12:45 PM
  #12857
Rattfink's Avatar
Default ride height
I bought a an almost new xray xb4 2018. during setup the only way I can get the ride height down to 16 in the front is to lay down the shocks. Any one else have any Ideas? or experience for astro turf setup?
Rattfink is offline
Old 03-09-2018, 01:10 PM
  #12858
Trader Rating: 33 (100%+)
if it hasnt been run much.. the springs will need time to break in.. other than that.. should be good to go.. are you running the longer shock ends?
dgrobe2112 is offline
Old 03-10-2018, 01:25 PM
  #12859
To get down to 14-16mm ride height while sticking with desired shock position you have to cut springs taking away one full coil.
They also have short springs available, hence preferred way is stay with cut springs, they tend to work better.
Rattfink likes this.
JanisK is offline
Old 03-10-2018, 09:29 PM
  #12860
Rattfink's Avatar
Not sure about shock ends I bought it used... barely. I am assuming stock kit ends. I have not seen any option for longer ends. However I have purchased an extra set of front springs So I can experiment...
Rattfink is offline
Old 03-11-2018, 12:10 PM
  #12861
Originally Posted by crusty View Post
hi there
The front lower brace, or wire cover, is used. I don't know anyone that uses the steering brace instead of the upper deck because we crash! With the steering brace only, the front of the buggy would be taking some really big impacts directly to the chassis/diff gear case.
More droop is always good for low traction. You can either use the stock 1.6/1.7 pistons or the 1.5-1.1/1.6-1.1 4 hole setup. You can start with unscrewing the shock ends 3 full turns for droop. Then measure for reference later.
LAGuy is offline
Old 03-11-2018, 08:50 PM
  #12862
AL1983's Avatar
Hi All,
Need help.
Just bought a 2015 XB4 with no rims or tyres. Wanted to as which pre -mounted/glued will fit stock xray hexes and same width, for dirt?
Thank for the help
AL1983 is offline
Old 03-12-2018, 09:48 PM
  #12863
Stevomatik's Avatar
What’s minimum weight for wheeler?
Stevomatik is offline
Old 03-12-2018, 10:23 PM
  #12864
1613g is weight for super stock 13.5
Old 03-13-2018, 01:52 AM
  #12865
dgdcustoms's Avatar
Trader Rating: 85 (99%+)
Does anyone have a secret stash of Hudy 600 weight shock oil??? I can not find any place that has any in stock. I need a bottle or two asap. Any help is very appreciated!
dgdcustoms is offline
Old 03-13-2018, 05:30 AM
  #12866
R/C Tech Elite Member
EricW's Avatar
You'll need to cut the springs to get down very low ride height (14mm). This is the solution that the Xray team drivers use.
EricW is offline
Old 03-13-2018, 06:59 AM
  #12867
Swooz's Avatar
Trader Rating: 14 (100%+)
Originally Posted by yxiaocheng View Post
Unfortunately no, because 2018 side guards have a vent for lower motor position. I am in the same boat as you because I have a pair of 2017 side guard...
I tried with the 2017 side guards and no issue
Swooz is offline
Old 03-13-2018, 08:05 AM
  #12868
RCAmerica has updated their website, go check it out. you can search any parts by number if you cant find them in the drop down menus.
It also has stock status of parts, so you can be sure they will be shipped to you.
https://www.rcamerica.com/
Old 03-13-2018, 02:00 PM
  #12869
Trader Rating: 156 (100%+)
And you can order through them which means no more Amain price gouging.
jpcopeland1 is offline
Old 03-13-2018, 04:27 PM
  #12870
I've been waiting for this to happen since the first day I bought a xray. Of course I'm all stocked up on spares now but will still order up some 3x2.1 orings and 2018 shock guides soon.
racingnewb is offline
