Like Tree134Likes
Xray XB4 thread
Old 07-12-2017, 04:29 PM
  #12421
Trader Rating: 39 (98%+)
Anyone running the composite pinion and diff gear?...I just installed them..just wondering how there holding up....I'll be running on a carpet track
tripple is offline
Old 07-13-2017, 06:22 AM
  #12422
Found my info
tripple is offline
Old 07-16-2017, 10:39 AM
  #12423
Ran my 16 xb4 w/ medium plastics on some outdoor clay yesterday. Track was hard packed w/ dust and wouldn't form any kind of blue/black groove. I ran the Tessman desert classic set up that I was advised to use in this thread. Not the whole set up but most of it (not the same diff fluids/ran a center diff/few other things). Car was pretty darn great, rear end was almost too hooked up when tires were hooking up good. I have my servo speed turned way down and expo's turned way down. Car was super easy to drive and could of probably been on pace w/ the leader in the right hands. Best outdoor experience so far w/ a 4wd buggy. Bumped up to the A finished 6th, first time running at that track. As normal no breakages
Sean B. and Phillip F like this.
racingnewb is offline
Old 07-16-2017, 01:40 PM
  #12424
Trader Rating: 77 (100%+)
Default Need Steel Drive and differential bevel gears
Running on turf and despite having the slipper setting to the manual specs, I think the slipper was too tight and my drive and diff bevel gears are starting to grind. I have the slipper set as loose as it will allow and I still don't really feel it slipping. That being said, the steel bevel drive (X-RAY 365134) and steel bevel diff gear (XRA364955) are out of stock everywhere. Anyone know where I can order them in the U.S.
On a related note, another XB4 driver at this track said he had to sand his slipper spring down on each end in order to get it short eniugh for full adjustment so that it could be set to slip. Has anyone else experienced this?
Wease is offline
Old 07-16-2017, 01:51 PM
  #12425
Have tried squeezing the spring with pliers? Mine is set all the way loose and it slips just right, but it was not slipping that good at first.
AJrollin is offline
Old 07-16-2017, 01:58 PM
  #12426
Xray 365134 steel bevel drive gear 14t
XRA364955 XRAY XB4 Steel Differential Bevel Gear 35T | eBay
Sean B. is offline
Old 07-16-2017, 03:57 PM
  #12427
Trader Rating: 61 (100%+)
Anyone interested in a super duper fully loaded XB4 pm me.
todb is offline
Old 07-16-2017, 08:03 PM
  #12428
Default Medium plastics
Do you really notice the difference between running medium chass guards and medium chassis braces as oposed to running the hard plastics?
crowie03@gmail. is offline
Old 07-16-2017, 08:39 PM
  #12429
Pville Stig's Avatar
Flex creates grip.
Pville Stig is offline
Old 07-17-2017, 12:15 AM
  #12430
Trader Rating: 31 (100%+)
I run on a wet dirt track. I ran my buggy with all hard plastics and was washing out every time I turn a corner. I started changing parts to medium. First, the arms... worked but need more flex to get traction... took out 2 screws from the center brace..... better.... changed the side guards to medium.....works now.
Phillip F is offline
Old 07-17-2017, 05:44 AM
  #12431
I ran the hard plastics during the winter on indoor med/high grip. Right before outdoor season started I put the medium plastics on. So I never tried hard plastics outdoors. I started outdoor season w/ 500k in the center and it was close to a 2wd. I lowered the center diff fluid 90% thinner and I have plenty of drive out of turns/ tires wear evenly. A team driver told me to lower the diff fluid to close to single digits and thicker in the rear then the front. He said it will sound crazy but do it and he was right car is hooked up.
Old 07-18-2017, 08:52 PM
  #12432
skrichter's Avatar
I will be running on clay. Curious if these do hold up with the center slipper???
I plan on running 13.5 mainly. Maybe some mod.
Thx!
skrichter is offline
Old 07-18-2017, 11:12 PM
  #12433
Trader Rating: 33 (100%+)
Thx!
They hold up fine in 13.5. I would not go crazy in mod with them
skrichter likes this.
dgrobe2112 is offline
Old 07-19-2017, 03:06 AM
  #12434
jmcelroy42's Avatar
Thx!
I run them in mine with a 5.5 and 1million in the center diff. They held up all last season at Innovative, a bit lower traction than you have at Dirt Heaven but you should be fine.
jmcelroy42 is offline
Old 07-19-2017, 08:54 AM
  #12435
suzukipro's Avatar
Depending on the bulkhead fit sometimes adding a shim behind the composite pinion helps prevent any issues with the ring / pinion.
suzukipro is offline
