Like Tree229Likes
Xray XB4 thread
Old 01-03-2013, 01:26 PM
  #901
DekelzMan's Avatar
Anyone else in Canada get one? I heard a rumour I might be the first..Picking it up Saturday
DekelzMan is offline
Old 01-03-2013, 01:36 PM
  #902
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
Yep, your the first.....Mr I've already got it in my signature B4 I own it,lol
sickpuppy1 is offline
Old 01-03-2013, 01:38 PM
  #903
DekelzMan's Avatar
LOL, well I knew it was coming so ummm..yeah I guess I jumped the gun by a week...
Old 01-03-2013, 01:57 PM
  #904
I would prefer the current battery bars instead of the carbon versions.
Yes, they look nice, but that's about it for me.
dennisV is offline
Old 01-03-2013, 04:02 PM
  #905
CarlCrocco's Avatar
Trader Rating: 92 (100%+)
Default My XB4 Fixes
Here are my fixes for the intial issues with the XB4.
For the front bulkhead, I made a brace. My frontbulk head is actually broken, but with the brace is working fine. I attached a picture of the brace, it was handmade so its not perfect.
For the CVD plastic pin retainers, I have been using some DEX410 parts.
Team Durango Driveshaft Bushing
Team Durango B-Type Driveshaft Pin Set (2.0mm)
These pins use a set screw and will not fly out.
For the leaky shocks I have been using the DEX410 Orings.
Team Durango 10x1mm Shock Cap O-Ring Set
Hope this helps some people.
I am hoping Team SR looks at my brace and makes a nice one.
CarlCrocco is offline
Old 01-03-2013, 05:08 PM
  #906
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I have a funny problem. My steering binds when the fronts at full droop. When loaded, i.e. on ground, its fine. I think its the steep angle on the ball studs thats causing it. Any fixes for it other than adding shims?
aloksatoor is offline
Old 01-03-2013, 05:19 PM
  #907
CarlCrocco's Avatar
Do you have the bulkheads mixed up? They are front and rear specific.
  #908
asc6000's Avatar
Trader Rating: 15 (100%+)
hmm, mine doesn't do that on droop. The angle isn't that severe. Full lock either way my rods are nice and free.
On the other hand at full compression there is a bit of binding at the cup.
Shock length 77mm eye to eye.
Changed a couple little things and anxious to get to the track tonight.
asc6000 is offline
Old 01-03-2013, 05:22 PM
  #909
Trader Rating: 22 (100%+)
I like that brace and emailed Team SR to see if they would make one for us.
Troy Carter is offline
Old 01-03-2013, 05:26 PM
  #910
aloksatoor's Avatar
No Andrew not the bulkheads. Else the diff CF plate wont mount proper. I will measure my front shocks as well. I think its some silly mistake I did most probably. I will disconnect each link and test again tonight.
Old 01-03-2013, 05:32 PM
  #911
RShockley's Avatar
Are the bulkheads labeled? I don't think mine are mixed up but didn't notice any differences between them while building it.
RShockley is offline
Old 01-03-2013, 05:51 PM
  #912
Autocratic's Avatar
Trader Rating: 26 (100%+)
I don't remember them being labeled.
Autocratic is offline
Old 01-03-2013, 05:56 PM
  #913
Theibault's Avatar
They aren't labeled but the front has a steeper angle were the top brace mounts vs the rear.
Theibault is offline
Old 01-03-2013, 05:58 PM
  #914
asc6000's Avatar
oh yea specific. not labeled but a good look from the side you easily see the area where the tower mounts is angled on the front one (leaned back for kick), the rear is straight up.
asc6000 is offline
  #915
asc6000's Avatar
fast typer
asc6000 is offline
