Old 10-28-2012, 03:26 PM   #1
Default Losing screws
I keep losing 2 screws from the bottom of my SCTE, there the two that go to my center diff bracket. Any suggestions?
Burlington T is offline   Reply With Quote
Old 10-29-2012, 12:21 PM   #2
dtr
dtr's Avatar
Which one? The front plastic one or the alu with the motor mount? If the plastic, then probably the threads are worn, you need to replace it. If the latter, then you need to use threadlock (or better/newer threadlock).
dtr is offline   Reply With Quote
Old 10-29-2012, 12:24 PM   #3
Put a drop of CA glue into a near-stripped plastic hole to get it to last a bit longer.
porterdog is offline   Reply With Quote
Old 10-29-2012, 01:03 PM   #4
lbenton's Avatar
Trader Rating: 48 (100%+)
If it is the plastic, I would suggest just replacing the part instead of using glue on it. The part is cheap and not hard to find. The glue might be an OK in the pit no time or parts fix to make one or two more heats... but it is not a repair.
If you feel the need you can even ditch the plastic and get something aluminum.. but of course any metal on metal threads I would agree, you need blue threadlock.
lbenton is offline   Reply With Quote
Keeping Dirt away from Chassis Screws. I Wheelie A LOT Electric Off-Road 20 08-08-2012 11:10 AM
Loctite Free R/C Screws and Nuts Tim35 Nitro Off-Road 44 03-03-2012 09:33 PM
Loctite Free Screws and Bolts Tim35 Electric On-Road 29 02-25-2012 09:58 PM
1/8th On Road Losing Popularity? jeffreylin Nitro On-Road 734 09-20-2005 01:25 PM
