Old 03-27-2005, 09:34 AM   #1
DJ_Normal's Avatar
Send a message via MSN to DJ_Normal
Engine mount problems....
Thanks for clicking.
I've got a 9.5 pro, and I went to install my O.S. RG-X, and then noticed my engine mounts don't have enough clearance for the pull starter. I need about 4mm more clearance. Does someone make pull-start engine mounts for the 9.5? If not, could I shim it with washers? The washer shims worry me because I don't want the engine moving around in there.
Also, what are the dimensions of the motor mount mounting screws (the ones on the bottom)? They are 3mm heads, but what is the thread size?
Thanks in advance for any assistant you can provide.
DJ_Normal is offline   Reply With Quote
Old 03-27-2005, 10:13 AM   #2
Trader Rating: 28 (100%+)
I'd say if you're going to shim it up, use a piece of aluminum the same size as the ears on the engine, then just drill the holes in it. That way the full ear is supported, and not just the circular area where it sits on a washer. Your other questions I can't help ya with, as I don't know the answers.
jbrow1 is offline   Reply With Quote
Old 03-27-2005, 11:03 AM   #3
DJ_Normal's Avatar
That is what I was thinking too, but I don't have the means to shape it properly. I'll have to start hunting.
Unless there is a manufacturer that makes them.....
Old 03-27-2005, 06:31 PM   #4
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
I've never owned an OS big block, but I know their small blocks come with "shims" that go under the engine mount tabs to raise the engine if you have a bumpstart engine mount.
If ya like, I can mail ya mine and you can give 'er a shot (but i'm fairly certain it wont really work)
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 03-27-2005, 07:41 PM   #5
Doesn't really take much to shape it properly. Just a hacksaw and file. Dremel works well too. Then just drill the holes in it. I've made em like that. The small block ones mentioned above will also work as servo shims if you ever need those.
Old 03-27-2005, 08:42 PM   #6
DJ_Normal's Avatar
Wow. Thanks for the generosity. Are they big block shims?
Old 03-27-2005, 10:26 PM   #7
Nah, they came with the SB's that i've gotten from OS.
but if i can dig up 2 sets of 'em, they're yours.
Old 03-28-2005, 10:25 PM   #8
DJ_Normal's Avatar
If they are for a big block, then I'll take them off your hands.
Old 03-28-2005, 11:00 PM   #9
do you have a dremel?
Old 03-29-2005, 10:16 PM   #10
Send a message via AIM to venomousRC
You should check with someone that has a GS Storm. The chassis holes should be the same, but if you want to measure them. I wil measure the mounts for the storm, Then you know what you need and they are cheap too.
Darin Gray
[email protected]
venomousRC is offline   Reply With Quote
Old 03-29-2005, 10:44 PM   #11
DJ_Normal's Avatar
I do.
I imagine the holes would line up the same as any other .21 engine mount.
Old 03-29-2005, 11:10 PM   #12
What I was thinkin is you could just get some scrap aluminum and cut it up
about 1/8" (if that) should do it.
%%%% RC8 FT Engine Mount and 2 Engine Mounting Plates jf45 R/C Items: For Sale/Trade 0 05-12-2008 04:56 PM
revo 3.3 engine mount, picco 26 maxx mount revoonroids R/C Items: Wanted to Buy 0 02-23-2008 11:43 AM
mugen x5 engine mount rcmike R/C Items: For Sale/Trade 3 02-15-2007 08:20 PM
kyosho v1s engine mount WHEELER Nitro On-Road 0 10-14-2006 09:55 AM
HPI Engine Mount kingjbh Nitro On-Road 1 01-24-2003 12:20 PM
