Castle creation NEED HELP
Hello Guys
I had just bought a castle creations sv2 motor esc combo 1406 5700kv
Im haveing trouble programming the esc for low voltage Im not running Lipos
at this time I have called castle creations about this and the guy I talked to read something off so oooooo fast I didnot understand one thing he said plz
I need a step by step on how to set the esc for low voltage so plz if you can help me I would be graetfull
THANK YOU
Jeff
THANK YOU
Jeff
It should all be in the little manual, thats how mine was anyways.
Tech Legend
Trader Rating: 51 (100%+)
You will want the voltage cutoff turned off. It is in the manual on how to do it by the lights or you can use Castle Link, the Castle Program Card, or if you bought it thru your local hobbyshop they should be able to get it setup for you.
