replacement shocks for mx-4 >
Old 03-21-2005, 12:00 AM
Default replacement shocks for mx-4
Hi,
looking for replacement shocks for mx-4, any suggestion ?
b3, xxx or xx4 ?
thanks.
ongbenghui is offline
Old 03-21-2005, 06:44 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
most of the guys use b3 shocks, but you may be able to get the others to work as well.
Tres is offline
Old 03-22-2005, 06:31 AM
will losi XXX shocks work on MX-4 ?
Old 03-22-2005, 05:57 PM
tony montana's Avatar
Trader Rating: 71 (100%+)
Dont know about the shocks, but does anyone have any idea were I can get a body and wing the for the car
tony montana is offline
Old 03-22-2005, 06:52 PM
mtn bkr's Avatar
Trader Rating: 18 (100%+)
You can get them directly from Yokomo at www.yokomousa.com. The part number for the body is ZM-104 and the wing is ZM-107. The B4 wing also fits pretty well.
mtn bkr is offline
Old 03-22-2005, 07:23 PM
thank you very much, you wouldnt happen to have a part listing and instruction manual would you
Old 03-22-2005, 09:31 PM
The Yokomo japan website got manual online.
http://www.teamyokomo.com/japan/manual/index.html
Old 03-22-2005, 10:01 PM
bender's Avatar
What's wrong with the standard shocks?
I found them to be much better than AE shocks, the only problem being that they tended to get a bit "sticky" after a couple of meetings.
I discovered this was due to the little white shock bushings that sit next to the o-rings. If you have the same problem then just ream the bushings out a little and the problem is fixed.
bender is offline
Old 03-23-2005, 06:37 PM
Nothing wrong. Got an used MX-4 that come with no very
good condition Losi shocks. Hence, looking for replacement.
MX-4 shocks will be rare and expensive to get.
