Tekin T8 chatter issue
I have been running my trusty T8 motor for a while on my surprisingly reliable hobbywing 80a 1/8 esc
when I had my losi 8ight i was running it with a nice short sensor wire, but since switching to the HB Ve8, I need a sensore wire nearly 3x longer. and it took me a while to get one. since then i've been running the T8 unsensored(after a lot of reading i found this was fine to do just not as smooth)
I had a local airplane shop order in a mile long sensor wire and hooked it up last night only to get terrible chatter from the motor and it will not spin up smoothly at all.
I take the sensor wire off and it spins fine.
any ideas?
any ideas?
Assuming the sensor board is fine and the ESC sensor port is good too... I would say a bad cable is likely to blame.
Take the motor out and bench it so the short cable will reach your ESC and give it a test spin that way... If it is good then you just need to try to find a better cable that will reach while it is all mounted.
sounds like a bad senser cable.
you can buy a 250-275mm sensor cable from any hobby shop...
http://www.amainhobbies.com/product_...or-Cable-275mm
any ideas?
any ideas?
