Orion Motor
#16
I run exclusively Orion motors at this point andhaven't had any problems with any of my Orions. As someone mention make sure you screws are of correct size (including length). Most issues that I have seen in regards to striped mounting holes have been due to using the in correct screw.
#17
This seems to be going on with my Orion Vortex VST Pro 8.5T. It seems to strip the screw or bolt not the CAN, but only on the side with the solder tabs. I can mount this motor in my DEX210 with lunsford titanium screws just fine but in my DEX410 I don't have any titanium motor screws yet and the steel one always strips with minimal and I really mean minimal effort. LIke butter!!
Anyone??
Anyone??
#18
99.9% probability it was user error.
Of the hundreds of motors that have gone through these hands the only ones that had a "screw" issue were a few in the early years.... cranked em a little too tight, screwed em in a little cross threaded, the dreaded mm/sae switch....
No big deal, do whatever you need to do for this motor and consider it a lesson learned.
#19
Anyone??
Anyone??
#20
I appreciate what your saying in that it's important to learn how not to over torque things. But this really isn't user error. I've been building these cars for more than 25 years and I'm confident in my ability to measure torque on a screw or bolt. I've gone back and tested this same motor with the same holes in my 210 rather than my 410 and also using the M3 Lunsford titanium screws that I normally use in the 210 I'm able to get a nice level of torque and mount the motor just fine. For some reason the standard steel M3 cap head screws I'm using in the 410 seem to strip but only on the top side. The bottom side (side without the solder tabs) tightens down quite nicely. I'm going to get a new set of steel M3 cap head screws and try again, perhaps the batch I have is wrong or something.
#21
I've removed my comment as I didn't feel it was necessary…sorry.
