Team Associated SC10B Race Buggy >
Old 09-28-2012, 02:55 PM
  #31
lbenton's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Wildcat1971 View Post
I am guessing the price point will be the same as the SC10RS. Same electronics.
Saw something that the rtr street price was $300.
lbenton is offline
Old 09-28-2012, 03:02 PM
  #32
Tech Legend
Cain's Avatar
Trader Rating: 253 (100%+)
saw on tower sc10b mounted front tires ...
Cain is offline
Old 09-28-2012, 03:15 PM
  #33
Wildcat1971's Avatar
Trader Rating: 82 (100%+)
the sc10rs is $299.....lol
Wildcat1971 is offline
Old 09-28-2012, 03:16 PM
  #34
does anyone even make tires for the sc10B sized rim? beside the rtr tires?
Old 09-28-2012, 04:47 PM
  #35
JEDI BASS's Avatar
Trader Rating: 23 (100%+)
Losi SCB front and rear wheels are the same size, just need a hex conversion kit to make the fronts and rears swappable and/or compatible w/ the Losi 4x4.
Somebody will figure a way to run normal truck tires on the front of the AE buggy.
JEDI BASS is offline
Old 09-28-2012, 05:27 PM
  #36
Odin544's Avatar
Trader Rating: 93 (100%+)
All the other SCB's use SC tires and wheels. I believe these are the same way. They just look narrow up front because of the tire and tread design. No reason why AE would make an oddball wheel. They don't typically operate like that.
Odin544 is offline
Old 09-28-2012, 05:31 PM
  #37
I have 2 sc10's so looks like one will be converted to a scb if possible
Ninetyeight740 is offline
Old 09-28-2012, 07:21 PM
  #38
azwheelman's Avatar
I LIKE IT !
azwheelman is offline
Old 09-28-2012, 07:47 PM
  #39
Moderator
ilanstylz's Avatar
Trader Rating: 142 (100%+)
I'll wait for the FT version to come out, when the losi came out with their's it was popular at my local track so with ae's version I forsee it coming back strong again.....
ilanstylz is offline
Old 09-28-2012, 09:53 PM
  #40
Trader Rating: 96 (100%+)
So are these rims hexes like the SC10 RS? I have like 6 sets of tires but they're rear pin and front bearing style.
eddiemoney13 is offline
Old 09-28-2012, 10:04 PM
  #41
so convert it to non hex.....
Old 09-28-2012, 10:11 PM
  #42
So does that mean the rims on this SCB are hexes?
Old 09-28-2012, 10:24 PM
  #43
Guest
Default front tires and rims
man the only thing i see, that i dont like is the narrow front tires and rims, i think they should have used the same size rim and tire all around. but i guess u can if u put the hex hub conversion on it.
i wonder if the sc10 corr big bore will fit this buggy?? that would be cool!!!!!!!!!!!!
LOSIRACER77 is offline
Old 09-28-2012, 11:01 PM
  #44
yes it has the hex on it like the sc10rs. you dont have to use the narrow rims. I assume the front arms are longer to make the width right.
Old 09-28-2012, 11:35 PM
  #45
Trader Rating: 57 (100%+)
Guys it's pretty simple... Yes the stock front wheels an tires are thinner just like the axial terra buggy, but it still uses a 0 offset rim (look at the pic on pg 1). So you can run the regular width zero offset hex rims or +3mm rims that fit the sc10rs, sc10 4x4 or any hex converted sc10's on the front or rear of the buggy.
Prostreet314 is offline
