The AE FActory Team B44.2 Thread >
Old 11-25-2012, 12:32 AM
  #916
rigor's Avatar
Trader Rating: 44 (100%+)
Originally Posted by fq06 View Post
OK... what's the deal with these spring cups?
Offset? I haven't made heads or tails of the numbers on the cups... don't really seem to make pairs. 2, 3 & 4 look to be the same, but their 2, 3 & 4
Ignore the numbers on the cups for a second and just look at their height... You'll see there is 3 sets in 3 different heights (offsets). The numbering scheme used by AE (for whatever reason) was to label 1 through 4 on each height set... So you'll have 3 cups that are all stamped "2" and each one will be a different height. Don't use the tallest ones.
rigor is offline
Old 11-25-2012, 12:35 AM
  #917
dMITIj's Avatar
Cool, thanx. Wasn't sure if it was short or long. I find immovable objects with whatever I'm driving often so figured I should put these on before I even show up at the track
By the way...
I have a savox 1258 and didn't want to get a new servo for this kit so I threw it in. Clearance issues. Did some trolling and most posts I found people were hacking up the case to allow the linkage to pass.
I sanded the face of the servo mount down 0.5mm and I clears just fine now. Just wanted to put that out there in case anyone else is trying to fit that servo in.
Same here, but i also sanded the servo to make it fit
dMITIj is offline
Old 11-25-2012, 12:48 AM
  #918
rigor's Avatar
I have a 1258 Savox as well, and i just didn't use the plastic servo mount spacers included with the kit, and it was fine. Same as my 44.1
rigor is offline
Old 11-25-2012, 01:44 AM
  #919
dMITIj's Avatar
i to have the same 1258 and didtent use the spacers but it still were grubbing on the servo.
dMITIj is offline
Old 11-25-2012, 05:27 AM
  #920
thebomber's Avatar
Originally Posted by racer1812 View Post
I'm man enough to admit that I thoroughly tested my stock cups, never saw any undeserved issues. that's all I'm saying. No cracks or splitting that would seem to be a defect..
You have a funny way of saying you didnt have any issues by pretty much saying those of us who have arent very good drivers. Theres enough data points in this thread alone to conclude "inherent defect". Mine split along the parting line. Im sure its acting as a stress riser. Could be a mold temp issue also or maybe an overtight ball end pocket. What ever the reason tney break to easily.
thebomber is offline
Old 11-25-2012, 05:28 AM
  #921
thebomber's Avatar
I was able to avoid the interference by omitting the spacer also.
Old 11-25-2012, 07:17 AM
  #922
fq06's Avatar
OK, I guess "offset" threw me. I think of that as spaced left, right, forward or back which would make no sense. I guess that is up travel limiting that AE is trying to say?
So everyone is limiting down travel internally by 1mm front & rear? Didn't notice any clips in the kit for that, what part are you guys using?
Really odd that 4 people had 2 different outcomes with the 1258 spacing. I also did not use any spacers and the bell crank would not pass the servo case. Same kit, same servo... no way to vary the build in that area
fq06 is offline
Old 11-25-2012, 07:32 AM
  #923
Trader Rating: 50 (100%+)
Ran my 44.2 for the first time last night on a large, fast clay track. Ran the box stock setup and loved the car overall. Only downside was that I had the same ballcup experience as many other apparently. Landed a smooth jump on the downside on my warmup lap and the ballcup split right down the middle and I DNS'd that round.
Aside from the bad ballcups, the car is world class. It was smooth, planted and very easy to drive fast.
stg099 is offline
Old 11-25-2012, 07:56 AM
  #924
I split a ball cup on my B44.2 when I landed cartwheeling. You can expect that. Switched the front cups out to RPM's. The only setup changes I have done was put Losi 32.5 in the front and Losi 30 in the back. It handles like a dream.
SRW141 is offline
Old 11-25-2012, 08:42 AM
  #925
thebomber's Avatar
It's probably a tolerance stack up issue (MMC) that allows some to clear and others not to.
Old 11-25-2012, 08:47 AM
  #926
rigor's Avatar
The shock shaft limiters are simply small clear plastic washers and are in a small bag by themselves within one of the bags inside the big bore build bag.
As for my Savox 1258 fitment, maybe I had lightly sanded one corner of the servo so it would fit in my 44.1 however long ago and just don't recall.
rigor is offline
Old 11-25-2012, 08:48 AM
  #927
fq06's Avatar
0.5mm is a huge... no massive variance in the machining world though
China manufacturing FTW!
fq06 is offline
Old 11-25-2012, 08:52 AM
  #928
fq06's Avatar
That's what those are... thanx.
Guess I'm going to redo my shocks then. Good thing they are a joy to build... actually want to do them again
fq06 is offline
Old 11-25-2012, 08:58 AM
  #929
rigor's Avatar
Page 18 step 1 all the way to the right...nylon spacer.
rigor is offline
Old 11-25-2012, 09:16 AM
  #930
dMITIj's Avatar
will the RC8.2e spring kit's fit the B44.2 and is it any good for the B44.2?
dMITIj is offline
