The AE FActory Team B44.2 Thread >
Old 01-01-2013, 11:02 AM
  #1531
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
NO drag break.
I find myself dialing out more and more break as well, allowing the car to turn while breaking if needed. Too much break and it will push..= bad
my $.02
racer1812 is offline
Old 01-01-2013, 11:25 AM
  #1532
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by racer1812 View Post
NO drag break.
my $.02
Most have so much brake they blow the gears out. I have mine set where the wheels still roll but slow the car down. Its takes a bit to dial that in.
It doesn't hurt to have a good 2x finger in the turns coming in and out to...
Mine slows down real fast but wont quite lock the tire up. And to mention drag brake means more heat as well.
UN4RACING is offline
Old 01-01-2013, 11:48 AM
  #1533
I haven't wuite figured out the best way to drive mine yet. I am more of an aggressive driver, lots of throttle and diving as far into the corners as possible with lots of brakes used. I'm not sure that's the fastest way, I'm sure smoother would be better but I get so much enjoyment out of pushing it to the limit. I drive my 1/8 e-buggies and SCTE the same way.
Zachfeen is offline
Old 01-01-2013, 02:11 PM
  #1534
rcfiend's Avatar
Trader Rating: 37 (100%+)
Originally Posted by rigor View Post
Can you make it out to WCRC this "4wd Friday" ? I'll be there all day and can help.
Jesse H.
I'm out of town Friday. I'll have to hook up with you when I return.
rcfiend is offline
Old 01-01-2013, 02:32 PM
  #1535
njnewc's Avatar
Trader Rating: 36 (100%+)
Got a question. What front rims go on the b44.2. I havea kit on the way and want to stock up. Are they 12mm hex?
njnewc is offline
Old 01-01-2013, 02:39 PM
  #1536
Suspended
Originally Posted by UN4RACING View Post
To try and do the impossible and get a real clean look. I put some servo tape on the chassis and secure the wires to it. Then I put some servo tape over it and fold it is so the top is also sticking to the ESC and servo.
How's this for clean?
PFKAOG is offline
Old 01-01-2013, 02:47 PM
  #1537
rigor's Avatar
Trader Rating: 44 (100%+)
Why did you bend your motor wires like that instead of just running them like every other pic of "clean" installs on this thread ?
Rigor's "Clean" Wiring
rigor is offline
Old 01-01-2013, 02:49 PM
  #1538
Suspended
Seemed like a good idea
PFKAOG is offline
Old 01-01-2013, 02:50 PM
  #1539
njnewc's Avatar
Front rims. 12mm hex?
njnewc is offline
Old 01-01-2013, 02:51 PM
  #1540
rigor's Avatar
Associated, Pro-Line, JConcepts, and DE Racing all make 4wd front wheels for the B44. They are NOT 12mm... more about 9.5mm
http://www.amainhobbies.com/advanced...+front&x=0&y=0
rigor is offline
Old 01-01-2013, 02:53 PM
  #1541
rigor's Avatar
With very little searching on your own, you would have had your answer 22 minutes ago (your last post). Have some patience if you're going to be lazy
rigor is offline
Old 01-01-2013, 02:54 PM
  #1542
njnewc's Avatar
Perfect thanks. Just making sure because non of the companies say B44.2.
njnewc is offline
Old 01-01-2013, 02:55 PM
  #1543
njnewc's Avatar
Thanks rigor ur a swell fella.
njnewc is offline
Old 01-01-2013, 02:56 PM
  #1544
Suspended
PFKAOG is offline
Old 01-01-2013, 03:00 PM
  #1545
rigor's Avatar
Ok that makes sense if you were uncertain
All B44 front wheels have been the same... Original, .1 , and .2 now.
rigor is offline
