tire glue or super glue
i have always used super glue to glue all my tires but should i use tire glue or is their any difference between the super glue and tire glue
Originally Posted by tyler144
(Post 11243480)
If you'd like a brand suggestion, I'll never use anything except AKA from here on out. Tried the Pro-Line thin and it was junk.
I'm a huge fan of loc-tite professional grade in the big blue bottle (not the control tube). It is pretty runny, but just thick enough to get a 1/10 tire all the way in the bead and locked before it grabs. I also use it for walking a big pool of glue around an 1/8 scale tire 1/3 the way each time. The bottle keeps the glue fresh until the glue runs out and you can get it at any hardware store or walmart. I've tried a lot of different glues and this is by far my favorite. It's towel smoke'n strong and the perfect consistency.
Wayne |
Originally Posted by klaymon
(Post 11244093)
Ive found the sweep or muchmore tyre glue to be the best ive used personally.:)
Seacret Glue
Originally Posted by Razathorn
(Post 11244142)
Wayne |
I have used Loc-Tite and Gorilla Glue super glues with great results . I do normally use AKA glue though . Use whatever works for ya !
I used super glue and other glues before and they work ok but are not the best let's face it that's why they make tire glue. With tire glue being cheap now a days, I can't imagine using anything else.
its all the same thing just labled differnt, there is a thread on this if search funtion is used.
Tire glue and super glue are both just CA glue. Tire glue is just thinner CA glue. You can get "super glue" that is more aggressive (thin and fast) or less aggressive (thick and slow) than tire glue. The only thing special about "tire glue" is that it that it is a specific thickness (see: speed) that the manufacture thinks is ideal for gluing tires. Note that each manufacturer has different opinions on what speed is best too.
You've got to find what works for you. |
Aka or loctite are the best that I've found, and I've tried a few. I'm guessing the aka and the loctite are the same thing.
Use a thin CA of any brand and you should be fine. It's more about prepping and glueing properly than X vs. Y brand of glue.
Originally Posted by DsWright
(Post 11245707)
(Post 11245707)
