Newb problem: on/off switch
Got a d8t, converted w/ Tekno kit.
Got Tekin Rx8 esc/motor.
My question is: where the heck do I install the on/off switch??? I can't see any sort of mounting bracket, and the directions don't refer to where/how to secure it down?
Many thanks in advance -
Step one, cut off switch
Step two, strip wires
Step three, twist wires together
Step four, solder wires
Setp five, insulate solder joint
Step six, ziptie
Step Seven, ???
Step eight, profit!
If you race some day the on/off switch will get you!
This public service anoucement has been brought to you by "Racers against on/off switches"
Step six, ziptie
Step Seven, ???
Step eight, profit!
Another question: this truggy uses the Losi 8t-e conversion battery tray. There is a plate for the esc to sit. There are 3 small holes on the plate. The underside of the esc has four VERY small holes. There is no real mounting hardware.
What's the answer to how best to mount the esc?? The holes don't line up, there's no bracket, no mounting hardware, nada. Thanks in advance.
Mount the Esc with servo tape, maybe even a couple layers, provides for some give, helps reliability.
Mount the switch so on is either forward or down, the direction of most big impacts. I never have switch issues this way.
Yep, most of the 1/8 esc failures happen on hard landings. A little give really helps.
Clean and dry the surfaces, maybe scuff them a little to break through surface junk & oxidation. Use good servo tape, I like the Parma/3M clear with the red backing. Check it regularly as part of maintenance. A loose zip tie over it as insurance doesn’t hurt though.
Add me to the + on eliminating the switch
PS- Doing so will not void the Tekin warranty
Just cut that mother trucker off !
Step six, ziptie
Step Seven, ???
Step eight, profit!
Step six, ziptie
Step Seven, ???
Step eight, profit!
Step six, ziptie
Step Seven, ???
Step eight, profit!
Step six, ziptie
Step Seven, ???
Step eight, profit!
