radio shack charger
Old 03-16-2005, 12:51 PM
Default radio shack charger
i recently bought an epic 3000 mah ni-mh stick pack. I have a radioshack one hour quick charger. Can I charge it with the radio shack charger?
takwing is offline
Old 03-16-2005, 01:08 PM
kamlooper's Avatar
Radio shack makes a zillion types of chargers. Tell us what it is first. You should really buy a good charger..., novak, LRP, tekin ect.
kamlooper is offline
Old 03-16-2005, 07:33 PM
it's a standard radio shack, one hour charger. cuz like it's not on the website anymore cuz itt's discontinued. But basically
it can charge ni-cd and ni-mh and it like a big charger, not like those plug in the wall chargers.
basically, my question is
does it matter than a battery is over 3000 mah? As long as the charger can handle ni-mh it's ok right?
takwing is offline
Old 03-17-2005, 02:01 PM
Yeti35's Avatar
I personally would not do it if I were you. I don't think it will be up to the task of properly charging those cells. As the previous poster said, look at Novak, LRP or the like for a good charger. Not to mention that stick pack probably has a Tamiya connector which will eventually melt down on you with a few charges in it. I would cut that plug off and solder on a Deans connector.
Yeti35 is offline
Old 03-18-2005, 01:21 PM
i do'nt have money for a new charger, can anyone tell me that i can use my radio shack charger? if not, anyone chargers (good chargers) for under 50? or 30 preferebly,
thanks!
takwing is offline
Old 03-18-2005, 04:11 PM
ThePrfctGetaway's Avatar
Location: If I told you, I'd have to shoot you in the face.
thanks!
Bro, that won't happen... I'd recommend a duratrax charger.. not TOO expensive yet it's pretty good... since you wanted something not too expensive...
On Tower Hobbies, that's 54.99 It's called the Duratrax Intellipeak AC/DC Pulse Charger. It can charge that 3000mAh, and not ruin it... That's the cheapest AC/DC from Duratrax....
ThePrfctGetaway is offline
Old 03-21-2005, 11:29 PM
maxxman101's Avatar
there is also this one HERE my buddy has it and it charges his 3300 with no problem.
maxxman101 is offline
