1/8 buggy style axles and 17mm hex for e-revo
i have seen a lot of revos develop slop in the center of the hex hub because the hex just sits on the threaded axle and was wondering if anyone makes a special set of axles without the threads on them or maybe a special set of 17mm hexes that solves this problem.
doesnt tekno rc set ups solve the slop problem
Huge thanks rustlererad3. i cant believe i didnt see this before.
also looks like these would be a shortcut: http://www.teknorc.com/shop/tkr10144...carriers-2pcs/ Edit- nevermind, didnt read the description. these still need the tekno carriers because of the larger size and different bearings. |
Integy makes these.
http://www.integy.com/st_prod.html?p...008&p_catid=29 There's an insert that threads onto the axle entirely, and the hex sits ontop of that, removing the slop. I actually just ordered a set. Integy is out, but I was able to pick up a set from Phil's Hobby Shop on eBay. |
Not sure of the part number but the brushless e-maxx and e-revo have 17mm splined hub that is a direct drop in and like $20
winddrake, thanks to you as well. i had thought of a solution like this and was hoping someone had manufactured it. thanks for doing the foot work and slogging through integy's clunky website.
