4 Pole motor selection for 1:10 Short Course
#16
I guess tower has it worng huh.
#17
Ah, that explains. I was kind of surprised since 4-pole was kind of revolutionary so I couldn't imagine an actual 12-pole setup in a motor the same size.
#19
For every mag their r 3 coils (so far that's the design in rc)
So a
single mag rotor as a novak 540 ballistic has 3 stator coils
Double mag rotor as a hacker air plain motor has 6 stator coils
4 pole rotor as in a tekin pro 4 has 12 stator coils....
Hope this helps .
Fyi for every style the esc sees the rpm multiplied by the poles which is a problem.with higher kv motors
So a
Hope this helps .
#21
For the Hobbywing 4-pole motors, you will want the 4700kv for trucks like the Losi scte. For the Durango and Associated, the 4000kv works great and has more than enough power.
#22
this: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBYUV
could not located any reviews on it, but decided to give it a shot anyways.
and I will report back when I get this exo all built and set up.
#24
this thing was expensive (I bought it at tower using my super saver discounts)
Moogumby - how many runs were on it? what were you running it in? how may cells?
and did trinity do anything about it?
thanks for the info
