Futaba Crystal
hello
wanted saver if this crystal is compatible with a Futaba 4-channel FUTK4200 72 MHz FHSS (Frequency Hopping Spread Spectrum) radio system of the aircraft. This is a two-stick radio band back in 72 or that type of glass that I should use to buy a receiver Sunupp Hobby SU/R-6FM/PPM 6ch FM 72MHz Receiver Compatible JR FUTABA RV218 thanks a lot for help!! |
The FM 72Mhz and FHSS are completely different and incompatible systems, the transmitter description appears to be in error. FHSS operates on the 2.4GHz band and does not use crystals.
If this is the transmitter and receiver you are referring to they will not work together. Futaba FUTK4200 Sunupp Hobby SU/R-6FM/PPM |
