associated rc10b4.1
associated rc10b4.1
I have a rc10b4.1 with the traxxas vxl system. The gearing is stock 21/81 and it is way to out of control what would be a better gearing setup
Suspended
Wouldn't that make it faster?
The problem is the VXL system isn't really designed for a car like the B4. Did you notice that it was not very easy to install in your B4? I can't recall (big hint that someone knows what they are talking about is that if they don't know they will tell you) if the VXL system has a training mode like the XL5, but if it does that would be about the only thing that might calm of down enough to be drivable in a small 2wd buggy. Realistically you need a system designed for a 2wd buggy.
You could change the settings on your radio as well. Changing the limits will tune down the throttle could be a quick fix. If you are having trouble with too much speed too soon you could change the exponential (I think, I may be wrong) throttle values. That may be with certain esc's and radios though. Correct me if I'm wrong.
