Kyosho Scorpion Ve XXL Thread
#301
Dan, you're a star! Diff has arrived and looks mint! (In the UK, that means better than good! )
It's been a tough day, so may not tackle the install tonight, I'll decide later.
Can't post my pic cos I'm too new here!
Thanks again, Dan! Much appreciated!
#302
Glad to see it made it to you safely!
Be sure to get pics of it finished before the install and some video of the Scorpion tearing shit up!!
Now that you have 10 posts you should be able to post pics!
#303
It's fitted and test run! All good so far! 5S and 6S, one pack of each from storage (to save time), ran sweet as a nut.
I'll get some pics up later.
Cheers, Dan!
Cheers, Dan!
#304
Hi guys I'm new to the forums and I have been following this thread for my recently purchased XXl. I got one of the CEN diffs from Dollar Hobbies and it should be here on Monday 2/5 so I'm looking forward to it.
I installed a Tekin RX8 gen2 and T8 2000kv system in mine and a Savox 1258 servo, It's very quick and powerful. I have the timing advance set to 10 on the RX8. I also threw some Badlands on the back, spray painted the front rims black and got the aluminum shocks
I see I need to make 10 posts before I can post a pic, so I'll try to get the post count up
I'm in Australia btw
Cheers, Gav
Cheers, Gav
#305
Cheers, Gav
Cheers, Gav
What voltage are you planning on running? On 4S the diff will last a while, but any higher and it won't last at all. Definitely worth getting the CEN diff modified and installed from day one.
I wouldn't class the Scorpion as a hardcore basher, but it is a great drive that can survive a few tumbles, I know mine has!
RPM only make parts for popular cars that have flaws, I hope they make some bits for this. I've got T-bones fitted to mine, the front bumper definitely offers some protection to the front of the car.
I'm thinking of doing a desert fast attack vehicle theme on mine, sand coloured of course.
#306
I broke my ET48 today. So now it's XXL 1 & ET48 0 over the same jumps, maybe I need a Kyosho truggy. lol
#307
Hi,
I might change the ESC timing to +15 and go up to a 17T pinion.
I've been looking for various hop ups, but there's nothing. I will buy the alloy shock towers soon, and probably the front steering blocks, not going to worry about the alloy wing mount though
#308
I'm running 4S, GenAce 5000mah 40/80C and using a 16T pinion, and with the RX8 timing at +10, I'm getting low temps, 50 celsius for motor, 45C for ESC, and the lipos, well only just warm
#309
I did exactly what you told me not to do Tug, but because I have the new CEN diff here I thought I would up the timing to +15 and see what happens. It was doing wheelies and digging trenches in the grass for 5 minutes, then bang !! there goes the diff
The good thing is the electronics didn't get much hotter, only up by 5 celcius
#310
Do post some pics as you upgrade it.
#311
Nice, looks like an excellent job, what diff oil do you recommend, I noticed 30k was mentioned earlier.
I'll try and shave some off it with a drill and drill bit, or even a file as my drill bits are old and blunt really (time to buy a new set) if that fails I will just take it to my local machine shop and get them to do it
#313
Yeah, Dan did a great job, perfect fit first time. I'll have to source a diff and have a go myself.
I used 7k, I wanted the car to handle as well as possible, seems OK so far. When the dry weather returns, I'll shoot some more vid.
#314
I drive on a fairly bumpy grass paddock with badlands tyres, what weight diff oil would you suggest ?? I only have 7k and 30k, but was thinking of doing a half and half mix making it roughly 15k
#315
If you don't mind the strip down each time, try them all, but 7 or 15 would be my choice. It's all down to personal preference, I don't like cars that just do donuts, so the ability to get off the line efficiently is important to me.
Last time I drove the car with a stock diff, it was on very bumpy ground. I remember hearing the diff gears crack as the nearside rear wheel dropped into a hole (not so much a hole, but a depression in the ground) under hard acceleration. This gave that wheel the nanosecond it needed to spin up to high speed, before making contact with the bottom of the hole. That was the end of that and I knew that after three diff failures, I needed something better; Dan and his cen diff mod.
It's yet to be driven in anger, but I'm still confident that this will be the cure for a problem that should never have existed!
