traxxas 3500 vs Nosram 10.5 >
Old 08-24-2012, 10:59 PM
OMG23RC's Avatar
Trader Rating: 21 (100%+)
Default traxxas 3500 vs Nosram 10.5
Hi,
I was just wondering what would be faster in a 2wd slash gear 14/54? a traxxas velenion or a nosram motor.. :http://www.nosram.com/en/products/el...-105t/details/
OMG23RC is offline
Old 08-24-2012, 11:11 PM
The Traxxas motor is a wonky Tripole motor, and makes good power for what it is.
However, that Nosram 10.5 is going to smash it in torque, while having the same RPM.
WindDrake is offline
Old 08-24-2012, 11:59 PM
OMG23RC's Avatar
so in top speed, which one will be faster? also is the nosram better than a reedy 943?
OMG23RC is offline
Old 08-25-2012, 01:28 AM
OMG23RC's Avatar
i was just looking the nosram motor is rated at 3600kv and the tekin redline is at 4600kv??? does that mean the tekin would be much faster? i dont understand they are both 10.5t
OMG23RC is offline
Old 08-25-2012, 02:57 AM
OMG23RC's Avatar
and then i look at power... nosman use 302 watts and the tekin redline use 243 watts ?!?! what should i base speed on or do all 10.55t motor go the same speed?
OMG23RC is offline
Old 08-25-2012, 07:33 AM
if the nosram has more torque then it should be faster due to you could run a taller gear and it should run cooler.
at least thats the way I see it but i could be wrong
68sportcoup is offline
Old 08-25-2012, 08:16 AM
jsinclair's Avatar
kv rating is inconclusive between manufacturers because they don't list the amount of timing used for testing. As it wattage because they don't list the voltage they tested at to come to this conclusion. Other than 17.5 turn motors, most two pole sensored motors are very close on the track when ran in blinkey mode. If you start running boost and turbo, the brand of motor starts to matter less and less.
jsinclair is offline
Old 08-25-2012, 11:12 AM
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
run a revtech 17.5 maxzilla, 3300kv and if your racing they will always have a 17.5 class
84 GT 5.0 is offline
