Novak motor question.
I'm running a Novak GTB ESC in a HPI Blitz. I have a Novak Ballistic 17.5T, 13.5T and 10.5T motors. I know the 17.5T motor is not fast at all but the 13.5T and 10.5T motors should be faster but they just seem to be slow for me what Novak motor should I be running in my SCT to equal a 4 pole 3200KV sensorless motor (I was running this motor before I switched over to Novak motors and ESC.)
Thanks for the info but I'm a little confused cause I also have a hobbywing 10T motor (I run sensorless motors with sensorless ESC in the Slash) and its much faster then my Novak 10.5T motor. And I don't have another sensorless ESC cause I use it in other cars. I do have a sensored Novak GTB ESC that I wanna run in an HPI Blitz and this is why I was wondering what Novak motor I should pair it up with to run at the same speed as the 3200KV and 3500KV motors.
The turns in a motor are not everything, the quality of the wind and the materials also make a difference.
If you want to stick with Novak (you don't have to) look at their 540 can motors and 8.5 is probably as low as you want to go or you will have a burnout machine
Well you see this is where it confuses me cause on the Novak's website they rate the 10.5T ballistic motor at 4600KV but I just don't get that much speed out of it. I have the same exact set up on my Slash I have a Hobbywing 10T 3500KV motor and with the same gearing it flies. If I run the two trucks side by side the Slash easily outruns my Blitz. So this is where I don't get how a 10T 3500KV motor with the same gearing can outrun a 10.5T 4600KV motor with the same gearing. Is the spec wrong on the Novak.
