Thoughts on 6 pole brushless motor. >
Old 08-14-2012, 07:16 PM
M03Racer's Avatar
Trader Rating: 33 (100%+)
Default Thoughts on 6 pole brushless motor.
I just saw that some manufacturers are making 6 pole motors. I see they are for mostly 1/8 would there be any advantages in running these in SCT 2wd or 4wd.
M03Racer is offline
Old 08-14-2012, 07:24 PM
Devigili22's Avatar
Trader Rating: 29 (97%+)
I don't know if a 6 pole can be a high enough kv to be fast on 2s.
Devigili22 is offline
Old 08-14-2012, 07:54 PM
6-Pole is going to have an absolute crapload of windings in it. No way you could run it on 2S for respectable speed, too low a kV.
WindDrake is offline
Old 08-14-2012, 07:55 PM
tc5 man's Avatar
Ever looked at the Tenshock 2100kv motors for 1/8 scale that run on 4s
Yea i agree that would be to many amps to run on a sct 4wd on 2s at least not to mention it would be a rocket !
tc5 man is offline
Old 08-14-2012, 08:44 PM
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
No way, need to just set a SC4x4 rule with a Max rpm limit of 34,000 rpm, so everyone can run what ever battery/motor kv combo they want within reason .
Any hoo I don't even think a 6 pole could fit inside a can of a 540 motor. I have seen out runners on plains and hellieslike that tho
jlfx car audio is offline
Old 08-14-2012, 10:02 PM
tc5 man's Avatar
You know what i never got why tracks havint thought about that one . I guess it would be to confusing maybe for newbies getting into 4x4 Sc .
tc5 man is offline
Old 08-15-2012, 05:45 AM
ta_man's Avatar
Trader Rating: 154 (100%+)
Tekin Pro4 4600 would be illegal under this rule (4600 X 8.4 = 38640).
Perhaps 40,000 RPM would be a better choice.
ta_man is offline
Old 08-15-2012, 10:36 AM
lewis110's Avatar
I believe they use 7.4 volts as a standard measurement. Comes to 34040 rpm
lewis110 is offline
Old 08-15-2012, 12:20 PM
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
i run a tenshock x802 6 pole 1650kv and its an absolute monster. tenshock also makes motors in 36mm x 50mm that are 6 pole not sure of the kv ratings
84 GT 5.0 is offline
Old 08-15-2012, 12:23 PM
84 GT 5.0's Avatar
http://www.tenshock-motors.de/Tensho...ole-TSCZ2230_1
Old 08-15-2012, 01:22 PM
Krio's Avatar
Trader Rating: 154 (99%+)
Having a max rpm doesn't govern horsepower in any way. A 10.5 2 pole motor has a similar kv to the pro4 4600, but the two are nowhere near the same when it comes to power output. 2s packs and not melting solder joints are the real limitations.
Krio is offline
Old 08-15-2012, 02:56 PM
I run a small 6-pole motor in my T4.1 . It a great performer, the only thing is it's a little too light for my application (I add lead when I run it). Forgot to mention, I run it on 6s.
ufoDziner is offline
Old 08-15-2012, 03:13 PM
So if u have a 2pole 4000kv motor (what ever given turn that is ), 4pole 4000kv,and a 6pole 4000kv motor even tho they would have about the same given Max rpm the HP is different. I can understand that if it holds true with the 6 pole .
Old 10-30-2012, 04:53 PM
lemonader83's Avatar
Trader Rating: 16 (100%+)
top speed? video? i'd like to see that go!
lemonader83 is offline
Old 10-31-2012, 04:22 AM
Top speed was the same as any other mod truck. I never took any video because there wasn't really much to see. I have since removed the motor because it just couldn't take the abuse from jumping. Had it been constructed more like a normal car motor, I'd probably still be running it.
